Question about Maytag Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
My Maytag side by side MSD2758DRW ice maker no longer makes ice. The arm was having trouble "pushing" the cubes out awhile back, so I disconnected the icemaker power coupling. I tried plugging it back in to do some troubleshooting, and the arm just keeps going around and around. No water comes to fill the tray. The water dispenser in the door works fine. Any ideas?
  • 1 more comment
  • stevepcguy Jul 11, 2010
    Additional info: I previously had problems with the fill tube in the past, so that was the first thing I tried. I checked the fill tube to make sure it was not frozen, and even ran the blow dryer to melt anything that might have been frozen in the fill tube.
    In addition, it seemed that the push arm was having trouble pushing the ice out, so when I used the blow dryer on the fill tube, it also seems to have warmed up the ice tray enough so that it was able to cycle once more. However, this was months ago, and I never got it to fill again.
  • stevepcguy Jul 12, 2010
    That was useless. The ice dispenser is not the issue, the ice MAKER is.
    To review:
    -Ice maker is not making ice.
    -No water is going into ice maker.
    -Fill tube is not clogged
    -If ice maker is plugged in, the roatating arm of the ice MAKER (not dispenser) keeps rotating. For lack of a better term, let's call it the rotating "ice pusher" that dispenses the ice into the bin.
    I'm leaning towards just buying another icemaker and installing it, but wondering if the issue is with the thermostat or another part.
    Does anyone read the comments? I already used a blow dryer on the fill tube.
    Next!
  • 532 Answers
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Posted on Jul 12, 2010
First thing to do is check that your ice maker fill tube in the back of your refrigerator is not frozen. The fill tube will freeze frozen solid and stop the water flow to the ice maker. Use a blow dryer (hair dryer) to melt the ice from the tube. The fill tube can also continue to freeze up from a leaky water inlet valve. Click on the link below to read more:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/16502-fixed-maytag-msd2756aeb-ice-maker-problems-no-water.html
Posted on Jul 10, 2010
    Thanks, I forgot to mention that I previously had problems with the fill tube in the past, so that was the first thing I tried. I checked the fill tube to make sure it was not frozen, and even ran the blow dryer.
    It seemed that the push arm was having trouble pushing the ice out, so when I used the blow dryer on the fill tube, it also seems to have warmed up the ice tray enough so that it was able to cycle once more. However, this was months ago, and I never got it to fill again.
    President:
  • 2,923 Answers
If the water dispenser works fine, but there's no water comes in to fill the tray, then I could say that there is NO problem with the water valve and the solenoid. You have to check the water supply line from the valve to the ice maker. Be sure that the water supply line is not kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
There's a possibility that the water supply line freeze up. And the line is clog, that's why there's no water coming in to the ice maker.
Try to defrost the fridge, locate the water supply line going to the ice maker. Use a hair blower and try to heat up the tube. This will melt the ice that's in the tube.
Thank you and good luck!
    President:
  • 1,561 Answers
  • The ice dispenser operates in such a way that before ice can be delivered trough the refrigerator door, the ice maker must first dump the ice it makes into a large bin. In order to get the ice, one must press a lever that activates a switch. The switch turns on a motor that rotates the auger and then the ice is pushed out of the bin, through a chute to the user.
  • The water dispenser works similarly to the ice dispenser. To get water from the refrigerator door, one presses a lever on the front that activates a switch. The switch turns on an electric water valve and water flows through the valve into a tube; it then flows into a container in the refrigerator to be chilled.
Take care.
Posted on Jul 11, 2010
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
The ice maker is not making ice. The water filter has been replaced and there are no trouble indicators from the lights on the front of the unit. The house has a water softener for whole house service.
Hello
Where the water comes into the ice maker.Be sure it is not frozen up.If it is, remove ice with a hair dryer.
Also,reset ice maker by lifting full ice tray arm and putting it back down.
Jun 05, 2011 | Maytag MFI2266AE Side by Side Bottom...
Maytag sidebyside msd2656kgb quit making ice S/N= 5019823jr the water line seems fine. ice is in the despencer I have lifted the arm up and down several time to no avail.
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 07, 2010 | Maytag MSD2656G Side by Side Refrigerator
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
913 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
