The server 192.168.1.1 at Linksys WRK54G V1.1 requires a username and password.
    Genius:
  • 1,027 Answers
Linksys username is blank
password is admin
if these are not correct press reset on back and try again, reset will set to default settings.
Posted on Apr 19, 2008
Lost installer/set up driver linksys model wrk54G
You don't need the disk. You should be able to log-in to the web interface of the router at this URL: http://192.168.0.1/
If you don't remember the password, you'll have to reset the router to factory defaults and then log-in with password "admin".
Dec 05, 2011 | Linksys Computers & Internet
Switched from DSL modem to Cable modem. Linksys
If you had your linksys router controlling the DSL connection, it was most likely a PPPoe connection requiring a username and password. Most cable companies have dynamic IP address and do not require a username or password.
Open your internet browser, IE, Firefox etc and go to 192.168.1.1 >
Enter your router username and password, typically admin and admin
In the setup tab, change your connection FROM whatever is listed there and make sure it is Autumatic DHCP Save your settings, and restart the router.
You should be fine.
Oct 27, 2009 | Linksys Wireless-G WRT54GS Router...
No setup cd for the Linksys WRK54G Router
hi! you can still setup your router even there is no setup cd. connect your ethernet cable to port 1 of the router and the other end to the ethernet port of the computer..press the reset button on the back of the router for 10sec.. unplug the power of the router for 15secs and then plug it back in.. pull up your internet brower and type in to the url: 192.168.1.1 and it will prompt the username and password.. by default the username is admin and the password is blank - means-leave it blank.. then it will show the setup page of the router....
Aug 07, 2009 | Computers & Internet
I set up a new server which is saying authentication required
Try leaving the username blank, default password is "admin. If it does not work, do you recall changing the router's username and password when you ran the cd that came with it? If you're still unable to get pass through authentication, reset the router by pushing the little reset button at the back for 10 seconds or so.
Jul 06, 2009 | Linksys RangePlus WRT100 Wireless Router
Linksys wirless GHZ 2.4 problem
Did you set the username and password for the router?
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Set up my linksys wrt52g2 v1
Go to this site and scroll down to the section "Configuring your Router to work with Port Triggering"
http://portforward.com/english/routers/port_triggering/Linksys/WRK54G/Warcraft_III.htm
The username & password for the router is by default admin/admin.
Hope this helps
Mar 16, 2009 | Computers & Internet
Attempted to secure my wireless and now can't access internet
You do not need the manual or CD
1. Turn off both the linksys and your modem
2. Turn on your and wait for the usual lights to turn solid
3. Turn on the Linksys and wait 30 secs
4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address
5. Now connect with an Ethernet Network Cable and make sure the internet is working
6. Disconnect the cable and Connect Wirelessly
This will connect without any security
To setup the security do the following:-
In order to setup your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer, safari, netscape or other internet browser
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try entering each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Enter a network name usually called the SSID
Find and enable security
Set to either WPA or WEP
Enter your required value:-
For WPA you may enter any letters and digits
For WEP only hexadecimal characters can be entered and for 64 bit its 10 characters
and for 128 bit it's 26 characters
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Linksys wrk54g setup
Many routers have a hole in them; stick a paper clip in, and it will reset itsef to its defaults. Go to linksys online to get the info you need--it will tell you it's default settings, and you can download the instructions. If you have DSL cable, the router will detect its settings automatically. Remember to encrypt it, or any one of your neighbors can use it to connect to the internet wirelessly. You won't have to bother if you connect through a cable to your pc.
Feb 29, 2008 | Linksys Wireless-G WRT54G Router
Initial setup no password
use-ly it is user name is (admin) password is (admin)
Jan 09, 2008 | Linksys WPSM54G Print Server
Connecting my westell 6100 modem to my router
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
Dec 09, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
