Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
I need replacement keys for logitech illuminated keyboard where can i buy them?
3 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: I love my Logitech Illuminated keyboard, however,
You could lift the key off to inspect underneath what's making it not work - sometimes dirt or dust gets accumulated. They should just pop out. Use a flat blade screwdriver and lift it out. To re-insert, align the key and push it back on until you hear a "snap" or click.
Posted on Nov 12, 2010
SOURCE: replace key on logitech illuminated keyboard
Since this happened to me accidently a few times and I saw this thread, I thought my 25 cents could help others. I like the keyboard and it is troublesome to send it back for repair for a little thing like this. In my case, I was left with the square black key top and a pair of white hinges detached. You should replace the hinges properly in the base board first and after that press the key top gently and uniformly until you hear a couple of clicks. Make sure you are not irritated when you start this job and do not apply extreme force. It needs a little patience and fiddling. Unless you are lucky or an expert, it takes a number of times until you get it.
The two hinges need to be inserted in the metal clips of the base only after they are put together, not individually. Each hinge has two little rods on the narrow side and two little rods on the wider side. The wider side rods face up and will attach to the key top later. By now, you should be sure which rods of the hinges are up, towards you. Next, the hinges have to be attached to each other in the middle, like a foldable beach stool. You observe that one of them has a middle pin on each side, whereas the other has a corresponding cavity in the middle.
At the time you attach the hinges to each other in the middle, it has to be in such a way that the top part of each of them is smooth, that is, the part that will contact the key top. The side of the hinge that contacts the base has a little tongue between the two narrow rods. This tongue should face down in both hinges. You are now ready to place the little beach stool in the keyboard base.
In my case I inserted the hinge with the open part into the right metal clip and next inserted the rectangular opening to the left metal clip of the base. Whichever you do first is easy, but the second one might need a little help with a tiny screwdriver, or a tool with a similar effect. You might need a few attempts.
Now, your little hinges are attached to the board base and are not flat. They actually look like the legs of an open beach stool. Note which side of the key top is correct, it is annoying to go back to the beginning because you put the character upside down. It is time to press the key top gently and uniformly until you hear a couple of clicks. Unless there was serious damage to the board base or the parts we just mentioned, the key should work as smooth as the other keys.
Posted on Jul 14, 2011
Keys on my logitech keyboard are not working
Without knowing which type of logitech keyboard it is, I'd suggest borrowing or buying another keyboard to see what the problem might be. The springs sometimes go bad, and it costs money to replace keys at retail prices, but sometimes it is easier to just swap keyboards, or takes keys from an identical keyboard.
Amazon and other online sites sell all kinds of keyboards and deliver them.
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs...
Apr 29, 2018 | Logitech Computers & Internet
When I press a key, why does it repeat numerous times or freeze, then repeat numerous times?
go into the bios of your machine and turn off the keyboard
repeat function, it may be that the keyboard is faulty or is too sensitive, either way this should cure the issue
Aug 09, 2015 | Logitech Wireless Illuminated Keyboard...
Where to get spare keys for this?? Logitech refuses to provide them. International shipping back and forth would cost almost as much as this low-durability keyboard did. Often used keys just come off,...
key boards ( usb ones ) are good at $10.00 aud so why worry about it , junk it and get another one
all are warranted for 12 months so if they stop working take it back for ma new one
Nov 24, 2017 | Logitech Illuminated Keyboard
I love my Logitech Illuminated keyboard, however, one key no longer functions properly. Is there anywhere that I could buy a replacement?
Nov 12, 2010 | Logitech Wireless Access Duo Optical...
How do i clean my logitech illuminated keyboard?
Take a paint brush (2") and with the Kb disconnected brush gently to the groves, then take some all cleaner and spray some to the brush (not to humid) and do the same, for finnishig you can use youe vac to take out dust and finally wipe gently wt a cloth.
Oct 20, 2010 | Logitech Illuminated Keyboard
Logitech keyboard,s keys are not working
Modern keypads arent as great as old ones where each key had its own switch and you could just open and fix it. new keypads have everything interconnected inside them. The only thing to do is buy a replacement, But if you really love this one keypad, you could try and clean it out with a blower and make sure the keys that are failing arent failing because of dust or unwanted debri.
Jun 20, 2009 | Logitech Keyboards&Mouses: Delux Plus...
S520 Logitech Keyboard keys are sticking
This keyboard is horrible. Several of the keys stick or will not work.
I called customer support which was not very helpful. They told me to take the batteries out of the keyboard then retry the keyboard and if it still did not work return it to the store I bought it from..
I like the set up of the keyboard but? to bad it does not work.
As I am typing this with my old keyboard because I can not use the the s520
Jan 01, 2009 | Logitech S520 Mouse
Lost bluetooth stick for my diNovo Edge
You might beable to buy a replacement key from logitech, and no any stick wont work, it has to be the one designed for use with the dinovo.
Jul 08, 2008 | Logitech diNovo Edge 9676850403 Keyboard
Replacement key caps
I would buy a plain dinovo for like 20 to 30 dollars and take it from there.
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_8bda69cf9239121b
Jul 03, 2008 | Logitech diNovo Edge 9676850403 Keyboard
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
462 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
