Question about Xante Accel-a-Writer 3N Laser Printer
I have accelwriter 3g printer and it has manual tray problem. Its not lifting paper from manual tray
  • Xante Master
  • 4,737 Answers
Please check the tyres [or U.S. tires or we also call them, pickup roller] which look like rollers and are fitted inside the paper tray. If they look shiny, clean them {if you can't see it, use a flashlight}
Pickup Roller
You need to check the Texture, if it's totally worn out and cleaning will not help, you'll need to replace it. But first try to clean it using a small ball of cotton dipped in alcohol or acetone and if you can see the improvement, go ahead, clean it properly and don't try to turn it manually, you may damage it.
If there is no other mechanism problem or technical problem, this will definitely fix your problem.
If you need further help, do let me know, Good luck.
Thanks for using FixYa.
Posted on Jul 10, 2010
  • 2 more comments
  • krantiindia Jul 10, 2010
    When a print command is given the Printer gives a TICK sound and stops showing Front paper Jam.
    Actually it is not lifting the Manual tray. sometimes if we press the bottom of the tray it lifts up.
    sometimes the front loader rotates continiously.
  • Lebanon Raingam
    Lebanon Raingam Jul 10, 2010
    Well, thanks for the info. That's exactly the pickup roller problem. Do as I've mentioned and let me know when you are done.
    Good luck.
    I tried it. But its not working. Tick sound comes from the left unit. there seems to be some issue there. pls suggest.
  • Lebanon Raingam
    Ok, firstly remove the Fuser Unit, take an A4 size thicker paper (slightly thicker than normal plain paper - photo paper will do the trick), push it inside the Tray until you hear the "click" sound. Release it and take another plain paper, give a print command while you look inside the Tray and when you see that the printer is starting pulling, push the paper inside and check whether it can pick up the paper or not. If this isn't helpful, you need to open the printer apart and check for paper jam (possibly pieces of broken paper/s is/are stuck on the passage or even a piece of hair or a piece of thread can create this problem). It's also possible that mechanism inside the paper tray is broken, so check the unit very carefully and clean it with blower and brush.
    Do let me know when you are done.
    Good luck.
HOW TO LOAD PAPER INSTRUCTION FROM brother instruction manuals FOR A
Pull out the paper tray.
Lift the cover of the tray.
Slide paper into the tray.
Close the cover of the tray.
Push the tray back into the machine till it clicks into place.
Aug 15, 2014 | Brother DCP 130C All-In-One InkJet Printer
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
Di2010
C0960
Manual Bypass Paper-Lifting Failure
The Manual Feed Tray Lift-Up Sensor (PC29) is
not blocked or unblocked even after the set period
of time has elapsed after the Manual Paper Feed
Pick-Up Solenoid (SL3) is energized after the manual
feed paper take-up operation has begun.
Check the bypass tray for obstructions and damage.
Jan 23, 2013 | Konica Minolta Office Equipment & Supplies
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Getting the msg "service call 22 man tray lift"...
This service indicator is referring to the main lift motor that is located on the rear of the machine, which comes in contact with the back of the tray and then engages to lift the paper up to the tray. I would suggest removing the paper tray and inspect the back of it, ensure that no parts appear broken and attempt to manually crank the arm that causes the paper to lift. If all is functioning on the tray side, then look towards the back of the machine through the front, make sure there is no lodged paper or debris. If no physical obstructions are present, and nothing appears to be broken and the paper tray aligns up properly, then you most likely have a failing lift motor.
Let me know.
-David.
Nov 08, 2010 | Minolta magicolor 2200 DeskLaser Printer
Where is tray 1 located?
Most Lexmark printers have two input sources. The Manual Feed Tree, located at the top back of the printer across the top of the printer.
And Tray 1. Tray 1 is located under the Paper Exit Tray in the front bottom of the printer.
You lift up the paper exit tray to reach the Tray 1 to change the paper size guides. It comes set up for 8.5 X 11 (Letter Size) paper.
Don
Feb 06, 2010 | Lexmark C533DN InkJet Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Xante Accel-a-Writer 3N Laser Printer Logo
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
