Http://www.acmehowto.com/howto/appliance/washer/washer.php
Please use this website above to help you isolate your issue, what you really need to do is get a Service manual for your exact make and model. Often the balance weight can come off, or the motor goes unbalanced. but you need a service manual to be able to troubleshoot,
Posted on Jul 10, 2010
SOURCE: I have a Kenmore 600 model 110.28622700 that
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.28622700&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
The problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Whirlpool has a replacement brake lining kit if you need it.
Posted on Apr 07, 2010
Feb 02, 2016 | Speed Washing Machines
Jun 02, 2014 | Samsung Washing Machines
Jul 19, 2017 | 1999 Volvo S80
Jun 09, 2012 | 2001 Chevrolet Blazer
Apr 07, 2010 | Frigidaire GLER642A Electric Dryer
Feb 11, 2010 | Washing Machines
Jul 23, 2009 | Washing Machines
Jun 30, 2009 | 2006 Dodge Ram Srt 10 Pickup
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
37 people viewed this question
