Question about Hitachi CPX325/320LAMP Projector Lamp for CP-X320, CP-X32
How do we open the projector to get the lamp out to place the new lamp in?
  • Hitachi Master
  • 12,061 Answers
Http://www.aboutprojectors.com/Hitachi-CP-X325-projector.html
Above is your manual below is a "How To"
www.maxflight.com/docs/change_infocus_to_hitachi.pdf
Posted on Jul 10, 2010
How do i replace lamp?
The lamp cover is accessed from underneath. Undo the screw. Remover the door. Undo the screws then holding the lamp module in place. Pull the lamp module out.
Fitting the new lamp is the reverse process. Don't touch the lamp glass with bare fingers.
Sep 13, 2014 | Mitsubishi HC5000 LCD Projector
How do i change the lamp on a epsom 83c
It's in the manual. But basically let the machine cool down completely. Open the lamp housing cover. Undo the security screw(s) holding the lamp housing in place. Remote the lamp housing as a complete unit. Put the new lamp with housing in its place. Do the reverse of the opening up procedure.
Remember to reset the lamp hours counter from the menu.
Sep 08, 2014 | Epson PowerLite® 83c LCD Projector
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
Green projection lamp not working
  1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
  2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
  3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
  4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
  5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
  6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
  7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
Nov 03, 2009 | RCA P52939 52" Rear Projection Television
Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
Jan 11, 2006 | Epson (V13H010L13) Projector Lamp for...
113 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
