Question about Apple PowerBook G4 Mac Notebook
What interrogative - Apple PowerBook G4 Mac Notebook
    President:
  • 2,571 Answers
Will need a lot more information to be able to help you.
What interrogative????
In linguistics, an interrogative word is a function word used for the item interrupted in an information statement. Interrogative words are sometimes called wh-words because most of English interrogative words start with wh-. In English, they are used in questions (Where is he going?
Posted on Jul 10, 2010
If the ignition switch fuse, starter relay, battery, and starter are all new, why wont my jeep crank
Here are some possible reasons:
Park/neutral switch is open.
Poor ground connection to starter.
You can test the park/neutral switch by either jumping the solenoid (connect the hot terminal to the start terminal to see if the starter cranks--if it does, the ground is good) or by interrogating the starter relay socket. To interrogate the relay socket, use a 12 volt test light connection the clip to battery positive. Probe the socket terminals with the test light. If only one terminal lights the light, your park/neutral switch is bad or the start wire to the solenoid is bad.
Feb 01, 2012 | 1997 Jeep Grand Cherokee
The car was running fine then it decided to not start. the engine dose not turn over. Checked starter and battery they are fine. Any ideas for our next step? would help a lot only car we have.
Hi, if it makes no sound at all, try starting in neutral. If that works, the problem is the transmission range sensor. If that doesn't work, I would recommend interrogating the starter relay socket. You would need a voltmeter to do that. If you have a voltmeter and would like the instructions for interrogating the relay socket, please get back to me. This is the easiest way to figure out what is wrong.
Oct 14, 2011 | 1990 Cadillac Deville
How can i learn the product name of motherboard? will i open the pc case?
that is the easiest way or download something like aida64, that will interrogate your system and tell you everything you need to know
May 05, 2011 | Computers & Internet
I have 2005 monte carlo it keeps over heating the cooling fans are not comming on I replaced the relays and its still over heating and I can't find the heat senser any help
The coolant temp sensor is on the thermostat housing at the back of the engine. See pictures below. Try taking the connector off the sensor--this should turn the fans on. If not, you may have a problem with power distribution to the fans. You can interrogate the relay sockets to verify that the PCM is sending a signal to turn the fans on. Please see my tip at http://www.fixya.com/cars/r6022358-relay_check on how to interrogate the relays. The PCM signal is a ground signal, so one of the socket terminals should be dead until the engine is hot--then it should become a ground. I have pasted the wiring diagrams below, but resolution on FixYa is not great. Please let me know if you have any questions.
3.4 liter coolant temp sensor location:
3.8 liter coolant temp sensor location:
Dec 12, 2010 | 2005 Chevrolet Monte Carlo
Hi i got a 1998 2.5 petrol jeep cherokee sport the peoblem i have no spark and no power to the coil but the petrol pump etc is working fine and petrol is coming through any ideas thenk you
First check fuse 20. If good, find the auto shutdown relay, probably in the box shown below. swap it with the horn relay and see if that works. If not, interrogate the relay socket to see what's going on. I pasted the wiring diagram below. Please see my tip at http://www.fixya.com/cars/r6022358-relay_check for instructions on interrogating the relay socket. These are generic instructions. If you get stuck, please get back to me.
Nov 25, 2010 | 1998 Jeep Cherokee
The cooling fan does not work, I hooked it up direct to the battery and it worked. I also checked the temperature sensor
probably the relay then. relays are usually in the engine compartment relay box. You should have 2 of them--high and low. There is also a 60 amp fusible link to check (see diagram below). Recommend you interrogate the relay socket with the engine running and hot to make sure the PCM is trying to turn the fan on. If you can't find the relay, please get back to me.
Oct 04, 2010 | 1996 Ford Contour
1999 Monte Carlo 3.1 theft deterrent
i would get the correct key... most locksmiths carry the GM keys
Sep 12, 2009 | 1999 Chevrolet Monte Carlo
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
I have a acer;extensa 5420/5120 series
Click -start-control panel-system-hardware-device manager. Look in the list if every thing is installed (no yellow interrogation) if you get this yellow interrogation click on it for more details and find the name of what you need then follow this link :http://support.acer-euro.com/drivers/notebook/ex_5410.html
choose your operating system XP or Vista, then download and install the driver you need. restart and it should do...
cheers
Dec 23, 2008 | Acer Aspire 5610-4648 Notebook
Apple PowerBook G4 Mac Notebook Logo
115 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
