Question about Samsung HP-T4234 TV
My Samsung HP-t4234 plasma tv turns off by itself and then starts clicking like it is trying to turn back on but usually never does. When I try to turn it back on it won't. It just keeps clicking. help please.
  • 93 Answers
SOURCE: Samsung 42" Plasma HPT4254
You need to either call Samsung if it is under warranty or get a TV repair guy for you.It is a common defective problem i have seemed from Samsung,but usually it happened within the firs 30 days.
solutiondoct
Posted on Nov 11, 2008
  • 195 Answers
SOURCE: my tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Posted on Oct 12, 2009
  • 610 Answers
SOURCE: my 50 inch samsung plasma tv turns off and on by
power supply needs to be replaced. common problem.
Posted on Oct 28, 2009
electrotech1
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
SOURCE: have a samsung plasma that keeps switching itself
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Samsung, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Dec 13, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Clicking noise and turns off and on. no bulging capicators. now what?
Hi the most common failures on samsungs sets are problems with the y and z sustain board for this I do recommend atechnician to check individually each part.
Apr 19, 2011 | Samsung HP-T4234 TV
My Samsung 42" Plasma TV starting turning off in the middle of watching a program and continues to click trying to turn back on. Can you provide what needs to be done to fix the problem. Thanks Danny
check for bad connections leve it running and check what is heating up on the power supply look for bad capacitors try borrowing esr meter check all the capacitators
Sep 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
I have a HPT4234 Samsung 42" Plasma HDTV that is about 2 years old and is making a clicking sound and not turning on or turning on and then off. Hundreds of people seem to be having this same problem. ...
It is more common on their lcd tv but I've seen it on the plasmas too. There are some capacitors on the power supply that are swollen (rounded or peaked on top) Look for these caps and replace with same type example 1000mf electrolytic. The working voltage must be at least the same or higher (never go lower!) example if it says 10v on the side replace with 10v or a higher value. Also put the replacement in the same way as the original They have a plus and minus to them like a battery.Very important as you can damage the parts and/or the tv.
Sep 12, 2010 | Samsung HP-T4234 TV
My Samsung HP-T4234 is not turning on. It "clicks" constantly as though it was trying to turn on but doesn't. If it should turn on, after a few minutes it turns off the picture and continues to "click". I...
I found it was the HDMI plug-in on the tv that my dvr plugs into went bad. There are two HDMI ports. I plugged the dvr into the other HDMI port and I no longer have any problems.
Apr 16, 2010 | Samsung HP-T4234 TV
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
My tv turns off by itself and makes a clicking noise
Oct 12, 2009 | Samsung HP-T4234 TV
Turns itself off and clicks back and fourth.
you have a power supply issue sound like bad capacitors they will be puffy on the tops and need to be replaced
Sep 22, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung hp-t4234
The color wheel have been broken, do not turn on your TV again to avoid big trouble with the DMD board, the most expensive part in your TV. Call technician to replace it.
Aug 14, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HP-T4234 TV Logo
626 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
