I have tried everything that was told to me.i am about to not buy a Toshiba again this thing is driving me nuts: use to work like a dream; sometimes when it began to go bad it would turn on with second boot. Microsoft virual C++ Runtime Library runtime Error! program:c:program files Toshiba flash cards R6025 - pure virtual function call
3 Suggested Answers
clark_styx
  • 282 Answers
SOURCE: C runtime error Program...\es\Roxio
did you upgrade to Internet explorer 7? try to revert back to IE 6 or uninstall IE 7
Posted on Oct 05, 2008
  • 77 Answers
SOURCE: When I open my yahoo
Uninstall yahoo messenger restart your system. Download and install a new version of yahoo messenger
Posted on Sep 30, 2010
My Creative Zen broke a few years ago, but the Toshiba MK3006GAL was still ok. I have since spoken to Toshiba who told me to buy a new connector so it can go to USB. My problem is that now, it only...
Try going into your device manager and finding your USB Mass Storage Device inside, where you saw it earlier. Once there, right click on the removable drive, and pick "Change Letter Drive or Paths" and change the letter to something else. Sometimes when you install a device that uses a letter, (say, "G" for example) and then install another device that uses the same letter, the initial device will not show up. If you change the letter, it should work. I hope that helped.
May 04, 2011 | Toshiba 30GB IDE Toshiba MK3006GAL 4200RPM...
Describe your dream machine sony icf cs10ip Problem Its power adaptor blew up.......what is the DC input,for me to buy a adaptor?
I have the same problem. I used in on a trip to Europe and plugged it in on 220v. Now I have to replace the power adaptor and I took it to 3 different repair shops. They all told me thye needed to know the specification of the power adaptor, like output voltage and mA in order to change it. But these info are not specified on the adaptor like it should. So I spoke to a sony representative over a online chat and she told me the adaptor doens`t come with the speaker, it's not from sony and they do not have this onformation I needed. So we tried with a 500 mA 3v and the clock was showing but there was not sound, the ipod was not being charged, etc. So we changed it to a 900mA and 6v. It works now! Well, I don know if these are the right specification but everything is working perfectly. I'm just not sure if it can get damaged after a while if these are not exactly the right voltage and power.
Mar 09, 2011 | Sony Dream Machine FMAM radio with...
Easy spa round - dream maker - overheat sensor is showing but can't get rid of it even when tub has cooled. Have tried unplugging and starting again. :(
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Jun 03, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a VW Golf 1.6 FSI 05 Reg, some times it drives like a dream and sometimes it feels like is struggling with loss of power, also, I lose power when the blower is switched on....help!!
could be numerous of thing and the list can go on, especially at times it run like a dream than other time it run horrible. Go to auto zone and have them plug it to computer for free and see if will throw a code, this way it will narrow it down instead of guessing and buying parts hoping that will fix the issue, this can be very expensive and there is no way to test the parts, beside checking the basic, plug, wires and coil. the computer will help narrow it down than guessing. then re post and one of us will try to walk you through it.
Sep 24, 2009 | 2004 Volkswagen Golf
Ascaso Dream water leak & bad shots
Hi
Sounds like you have a leak in the system. If your handy, you can remove the top. Remove everything. Water tank included. Unplug the machine. Now turn the machine upside down on a towel. There are 2 screws behind the brew head. Remove them, then lift the machine off the top and set it right side up. Now you can see the inside of the machine where the boiler is. Do not touch anything inside the machine. Replace everything and plug the machine in. Now turn the machine on and try to make a shot the same way. This should show you where your trouble is. Once you see where the trouble is, unplug the machine. Contact seattlecoffeegear.com, or 1st-line.com. They can help.
Jul 29, 2009 | Ascaso Dream Espresso Machine
I am stuck with the closed caption on. I have a univesal remote,
the only thing i would recommend is going to an electronics store and getting the controller any universal one they sometimes have the same actual controller needed and solving it from there is pie i would recommend best buy.
Jan 07, 2009 | Broksonic TV
Dvd-rom driver not working on toshiba satellite A65-S126 laptop
Ok here is the thing. the driver that you are referring to is native to the XP operating system. Meaning the driver is embedded. If the CD/DVDROM comes up under my computer that means only 1 thing. The driver is ok. if you have tried more than 1 CD and the drive still does not read it., it means only 1 thing. The drive is defective. if you use an external drive via USB you should not have any problems. If you do then you will need to reload Windows but that will be an unlikely event.
Jan 05, 2009 | Toshiba Satellite A65-S1065 Notebook
Toshiba Equium 3200m hard disk upgrade
From all of the specs, it appears that is motherboard only supports up to a 20GB drive. The way to add this drive is to buy a separate hard drive controller, but honestly that is a waste of money. By the time you finished adding pieces and parts to get everything to work, you will have replaced so much that you could buy a new system and alos have issues wiht some things not working.
Dell has a low end desktop for on $399 and you can find some things even less than that in their refurb section, with a warranty, for less.
Jan 04, 2009 | Toshiba Equium 3200M (PV1058U-4CNS2) PC...
Minlota 7d camrea useing sigma ef 500 super flash
check circuit of inside the flash,and clean the circuit, and check all the compenents..may be drysolder, chaeck every thing...
Oct 06, 2007 | Sigma EF-500 DG for TTL Flash
Computers & Internet Logo
David Payne
David Payne
