Question about Kenmore 16372 / 16374 / 16379 Built-in Dishwasher
Leaking from the bottom a lot, immediately when I start the cycle
My Kenmore dishwasher 16372 is leaking a lot of water from the bottom panel (not the part I can see when I open the door).  Leaking starts immediately when I start the cycle.
  • bpflynn12 Aug 29, 2008
    Water does not fully empty from the dishwasher. To correct the problem I would run the garbage disposal and the water would then appear to empty. I also made sure the stopper was in the sink. This appeared to help keep the water flowing during the cycle, however I would have to do this most of the time
    Water is leaking from the bottom of the dishwasher. I cleaned the seals that had collected food particles around and under the door. At first it appeared to have corrected the problem for a while but only for a short period of time.
  • tnapier Nov 18, 2008
    not sure what model number my dishwasher is but is from sears so it's a kenmore or whirlpool. I've had it for about 7 years it's leaking between the two panels only on one side.
Problem was that a rat or mouse chewed through the hose. I had seen small pieces of red plastic on the floor in the water. That was a clue that the plastic part of the hose had been chewed up.
Posted on Apr 20, 2008
How do I get error code f2e2 off my dishwasher?
"F2 - A water leak, which if detected will stop water from entering the dishwasher via the inlet valve. You will probably experience the dishwasher not filling properly during a cycle. Possibly caused by a faulty water level indicator, you can also try cleaning the filters and drain if you notice a lot of standing water remaining in the dishwasher basin."
"Look in the bottom of the unit. Something has it stuck, like food."
sorry if this doens't solve your problem. This is what turned up with your keywords in a quick search engine query.
Sep 18, 2014 | Kenmore Dishwashers
Should the water level be above heating element
The full water level will be 1/4 to 1/8 inch below the heating element. The water fills on a timed basis so the exact level depends on incoming water pressure.
Mar 06, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore Smartwash dishwasher leaks water
pull off the toe kick and get a flash light and see what is leaking. it might be simple to tighten a loose connection.
Jan 31, 2012 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore Dishwashier
This is caused by water not heating properly. I have put together some instructions on what to check and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if it works out for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 05, 2010 | Kenmore 16372 / 16374 / 16379 Built-in...
Water leaked out of bottom
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Apr 16, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I'm just wondering how much water should be in the dishwasher for proper cleaning? Should it cover the heating element?
Water level can depend on the model and manufacturer. The water will fill to the level of the float switch. This is a plastic looking thing near the front of the dishwasher along the tub bottom that looks like and upside down cup. The water level reaches a point to where the float lifts and activates a cut-off switch which will stop the water from filling, followed by the wash cycle beginning. Now, depending on where the heating element is located, the water level is usually just touching the element and not necessarilty covering it. Does this help you? If you still have questions, let me know.
Jan 01, 2009 | Kenmore 16372 / 16374 / 16379 Built-in...
I found this post on another website. Hope it helps:
"Six torx screws securing the fine mesh filter just below the lower spray arm. Make sure they're all tight. Bit size is T 20 also, check for damage to the mesh screen. What happens when those screws are loose is water pressure seeps under and creates a tidal wave sort of effect by spraying water forward instead of thru spray arm...long shot, but I've seen it 50 times."
Jun 29, 2008 | Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dshwasher has water on the bottom after cycle
Hi
Check the bottom of the machine and where water goes,there might be some scrap food,or other item that is not allowing the water to go in the time when the valve is open.This leaves some water and increases in other cycles,causing flooding on the floor.Also check for bend in the pipes at the back.
Hope this helps
jay
Nov 17, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
184 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
