Question about Homelite Mighty Lite Lawn Trimmer
What is the fuel mix ratio?for home lite 26cs please
    Master:
  • 502 Answers
25 to 1
Posted on Jul 10, 2010
Fuel ratio for home lite timberman chainsaw UT10910
If the cc is lower than 40cc, then go with 40:1
If it's higher than 40cc go with 50:1...
It's better to be safe than sorry when it comes to oil mixed ratios...
Oct 05, 2015 | Garden
What is fuel mixture ratio for home lite backpack
Newer ones are 4 stroke (gas only, thanks California) Usually 40 to one if you mean the oil/fuel ratio. If you mean the air/fuel ratio, who knows...
Oct 14, 2014 | Garden
What is gas ratio 50 t0 1 for homelite leaf blower
50:1 is the gas ratio... thats about 2.6 ounces of 2 cycle mix to one gallon of gas
Sep 14, 2014 | Homelite Garden
I need an address to purchase a fuel tank for my mighty lite 26cs . Model - UT21506 SN- ATK0712739
Go to psep.biz or jackssmallengines.com you will find all that you are looking for ! Godd Luck...
Aug 16, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
984 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
