Question about Nintendo DS Lite Console
DSLITE HELLO THE PROBLEM IS THAT MY DS LITE WILL SWITCH ON BUT THE SCREENS WONT COME ON,IVE TESTED THE SCREENS ON A SEPERATE DS LITE I HAD AND THERE WORKING FINE,WOULD THERE BE A PROBLEM IN THE MOTHERBOARD OR WHAT ?THANKS,HOPE YOU CAN HELP
  • martinoggie Apr 19, 2008
    ITS A NINTENDO DS LITE
  • 19,396 Answers
Check first screen connectore, if they are ok, then is the motherboard
Posted on Apr 19, 2008
  • 1 more comment
  • Ginko
    Ginko Apr 19, 2008
    Make and model is Nintendo DS Lite Console
  • Ginko
    Ginko Apr 19, 2008
    Sorry martinoggie, ask Maanita for help
  • Ginko
    Ginko Apr 19, 2008
    We both know ITS A NINTENDO DS LITE, Maanita will help you.
    Apologies and regards.
    Genius:
  • 1,142 Answers
Can u specify the make and model
  • Maanita Chadha
    Maanita Chadha Apr 19, 2008
    Sorry about the delay to get back with resolution please try the following:
    Check the flex connector joining the bottom half of the case to the top half. Also, when working on things like these, take precautions against static, such as an earthing wristband (cheap and easily obtained) or just earthing yourself to something earthed in your home (not a socket - play it safe! Think radiator pipe, etc.). Check all connectors, they'r easily displaced and can seem like they're fully home when they're not.
    The cable is probably damaged - it causes this fault. Unfortunately you'll need a new screen (eBay) but when fitting, be extremely careful, it's so thin and fragile it gets easily torn. The metal collar is a menace, but there is a way to get the cable hrough gently. Make sure the large end with the contacts goes through the slot cut out for it, then very gently pull through while feeding the rolled up flex through the cylinder.
DSlite purchased in UK, any usage problems in SOUTH AFRICA?
you wont have any problem with your dslite when you go to SOUTH AFRICA... you can use it as you like..
akuma_ryu21 rate it plss
Jan 21, 2011 | Nintendo DS Lite
Tip
My DS has power, but my screens are blank!
HELLO!!
I've seen countless amounts of Nintendo DSlites with this generic problem. If you have experience opening up electronics, you will find this to be a VERY easy fix. A fix that'll make you happy you didn't blow money on having a professional repair it. It doesn't take a professional to repair this. Continue reading :)
PROBLEM: A Nintedo DSLite that powers up, but doesn't display video. Here's what your situation should look like
  1. Nintendo DS has power. (power indicator light is either green or red.)
  2. Both screens (upper and lower) are both black/blank
What causes this problem?
- Your Wireless wifi board on your nintendo DS has gone bad.
How do we fix this problem?
- Simple, replace it :)
Here's what it looks like...
This is where it goes... (top left corner)
Easy Easy Fix...
If it helps, please let me know!
Great!
on Jan 01, 2010 | Nintendo DS Lite Console
Why wont my R4i card work with my DS lite??
Hello Princess,
There is a latest update for the R4i card that should fix that error. Do you have the real one? It should look like this http://www.dscardworld.com/dsi-cards/r4i-sdhc.shtml
Check the download page for the latest R4 SDHC software.
Apr 27, 2010 | Nintendo DS Lite
My Ds will not switch on. It worked this morning, it wont charge and it wont switch on either....It is a DS lite console, only 4 months old.
Your DSlite could have come into contact with liquid, OR the battery is bad.
Both are very possible and very likely.
I would try another battery before sending it out for repair. Aside from a blown fuse inside your Nintendo DS Lite, these are the only causes of no power.
Please try a battery first.
If that does not work, you will have to send this in for repair.
Goodluck and I hope I helped.
Apr 11, 2010 | Nintendo DS Lite Console
I turn on the DS and the screen flashes,THEN DEAD
Which screen?
If both of the screens flash and you've charged your dslite, i would say either your charger is bad, your battery is bad, or your charging port inside your system is bad.
You would have to try different batteries and chargers to pinpoint the problem. I recommend this situation before sending it in for repair, if repair will cost you some money.
If only 1 of the two screens are flashing, then it would have to be sent in for repair since Liquid damage or rips can cause this problem.
Hope I helped!
Apr 05, 2010 | Nintendo DS Lite Console
What should i do if my ds lite console doesn't turn on even after i changed the battery?
HELLO!
There seems to be a blown fuse. Search on the internet for "How to Replace DsLite Blown Fuse"
OR
There could be liquid damage to your board.
Dec 28, 2009 | Nintendo DS Lite Console
I have an R4i Neo card in a DSlite. Mario Kart
Pokemon White wont play on my dslite but al other games work. when is start up pokemon white both screens turn blank and the only thing that works to get this screens away is tto turn off the ds.
could you please help me with this problem i want to play pokemon white
Dec 05, 2009 | Nintendo DS Lite Console
Sons DSlite wont turn on has black screens Charge light comes on changed battery still nothing
he might have gotten mad at it and pressed down hard at the touch screen
Sep 05, 2009 | Nintendo DS Lite Console
Brought a second hand ds console lite but dont know how long to charge it for? please help dont wont to reck it
3 hours with the unit turned off.
http://www.nintendo.com/consumer/systems/dslite/battery_faq.jsp
Jan 14, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
