Question about Polaroid TDA-03211C 32 in. LCD HDTV
My tv is giving me sound but no picture the tv is only 2 yrs old what may be the problem?
  • 11,361 Answers
  • 3 Answers
SOURCE: Sound but no Picture
Most likely it is the board on the lcd panel. The first question though is, can you get menus? If yes, it is the input module, if no, most likely the panel controller board. There are several makes of panels in these sets, so once diagnosed, we would need to know what panel you have to help further. I can help you figure that out once you let me know if you get menus or not.
Posted on Mar 05, 2008
  • 6 Answers
SOURCE: no picture but sound
inverter gone bad.. one of the transformers sorted and when one backlight is off tv shut's others too.. if you can measure which one is sorted you can change it if you find new one.. first try http://www.lcdparts.net
Posted on Oct 30, 2008
djchillsnyc
  • 152 Answers
SOURCE: I have power, but no sound or picture
hello, thats is not true the power supply might have went out or something else. just cuase it dosent turn on does not mean the screen is bad the tv repair man might be.
if your not dyi or electronicly inclined take it to a qualified plasma and lcd repair shop before you give up on it.
i buy them like this .
if you didnt break your screen and it isnt cracked or shattered
if just went out, it may be a power suply problem try repairing your power supply or exchanging it.
remeber to allways get more than one opinion.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
Posted on Sep 18, 2009
  • 148 Answers
SOURCE: After turning on tv screen stays up for 1 minute
Hi there, first off, place a fan as close to the back of the tv as you can, this could prolong the use of your tv by cooling down the powerboard inside, The reason why your tv is doing this is becouse the caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thankl you!05f6799.jpg
Posted on Feb 05, 2010
Lg LCD tv less than 2 yrs old has sound but no picture. What could be the problem? power supply, main board, etc??
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 18, 2016 | LG Televison & Video
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,
Welcome, and thank you for using FixYa!
To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.
Have a great day!
Nov 10, 2011 | SunBriteTV Televison & Video
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Sound but no picture
that's a problem of signal that you have stayed somewhere that revirsarlo a osiloscopio
Aug 22, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Picture went out on TV
you need to change the sustainer boards and TV will be good as new.
Apr 05, 2009 | V, Inc. Vizio P4 Plasma Television
LCD TV has sound but no picture.
Shine a small bright light at the screen when on and see if you can see a faint picture in the dark screen. If you can then your backlighting is not functioning due to ccfl (inverter), power supply, or back light lamps.
Mar 27, 2009 | Philips 26MD255V 26 in. LCD TV/DVD Combo
No picture but sound
Oct 30, 2008 | Televison & Video
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Durabrand TV picture died. 2 yrs old
hats the shelf life on that tv
Jan 21, 2008 | Durabrand DWT1905 TV
Jan 08, 2008 | Proview HV-207 20 in. HD-Ready LCD...
Polaroid TDA-03211C 32 in. LCD HDTV Logo
226 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
