Question about York Exercise & Fitness
Wanting to buy a York T700i treadmill back roller part. delivery to new zealand
    President:
  • York Master
  • 832 Answers
You May have to go York in the UK to purchase parts or they may be able to direct you to a dealer Sorry Can't be more helpful.
www.yorkfitness.com
Posted on Jul 20, 2010
Hi My York Pacer treadmill is very noisy when it is on. I applied lubricant but did not help.
Normally when this happen
The Roller in front and rear ball bearing is damaged
Try to put a WD-40 in both sides for both Roller.
of Course look inside of motor if the bolt motor is loosen?
Otherwise replace both rollers.
LED Blink Patterns on the Control Board Treadmill
cuadra2016@yandex.com
cell+whatsApp:+50588611441
Apr 27, 2018 | York Exercise & Fitness
How do i change running belt for york paacer 4600 treadmill
Remove the motor hood cover, side foot rails, front and rear rollers,and walking deck. Takes about 2 hours to do
Mar 04, 2015 | York Exercise & Fitness
Hi there, my york pacer belt won't go around! Do you know how I fix this please?
see the video and lube the deck blet + rollers bearing too.
However if the problem persist, after you did, time to replace the old board deck belt, by new ones.
God bless you
Jan 09, 2013 | Exercise & Fitness
Hi there i have a york treadmill and we moved house and when they were moving it it lost all this oil and now the automatic release button does not work so easily and i think it is starting to smell a bit...
you need to buy silicone 100% FOR LUBW the deck belt and rollers bearing.
You need to buy in any store for tredmills.RFemember LUBE the treadmills by each 5 hours of use.
God bless you
Nov 16, 2012 | Exercise & Fitness
I need a key for a York treadmill 2750 can anyone help?
Dear Sir:
You have 2 options: you can buy from www.fitnessrepairparts.com or you can buy the small magnet from any Hardware store, Since the Key is a small magnet piece.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
Hesitation with the belt rotation. Less pronounced at faster speeds.
This is usually caused by a loose belt and can be tightened by the adjustment bolts located on the back of the machine on either side of back roller thru the holes in the shrouds
Oct 19, 2010 | Cybex International Cybex 520T...
I won the bid for a York treadmill , model 3502 on Thurs 22nd
If you live in Australia-
First check with your bank if payment has gone through to sellers account. You should of receipt of payment made to show you have transferred payment. Should take 24 - 48 hours to go through but all depends on receiving bank. Also make sure you have the sellers correct details - Account name, BSB number , Account number, Bank name etc. as if it's not exactly as on their account the funds will not be transferred back to you.
Jul 26, 2010 | York Exercise & Fitness
Where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Apr 11, 2010 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
107 people viewed this question
Top York Exercise & Fitness Experts
Mikee
richie46
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
