Question about Apple iPhone Smartphone
Touchscreen not working properly
When i on my phone its work properly only 1 minutes then its touchscreen not work i off my phone then i restart its again work only 1-2 minutes
Throw your phone away you ******!!!!!!!!!!!!!!
Posted on Apr 20, 2008
Touch screen not working / not registering touch
Follow the steps mentioned below until your problem is sorted.
1. Restart Your Android Device It works 80% of the time. Screen locking/managing applications often make touchscreen unresponsive. In that case you need to restart your Android device. How can I reboot my tablet, the touchscreen is not working.. Good question!
  • Grab your Android tablet/phone
  • Press and hold the Power Button for 10 seconds or until the screen goes blank.
  • Wait a minute or two and then power on your device normally using the same button.
2. Eject Memory Card and Sim Shutdown your Android device and remove the Memory card and Sim(s) attached to it. Also, remove the battery for few seconds if possible.
3. Remove Any Cases Smart cases are good in protecting your device from scratches and damage. But their automatic screen wake/sleep feature sometime cause the device to malfunction. Remove the case, perform a restart.
4. Hard Reset your Android For advanced users. If everything else doesn't work, try doing a hard reset on your phone. This will wipe your phone/tablet and return it to its original condition. This usually involves holding down Volume-Up and Volume-Down button together and then pressing Power Button (every phone has different method). It starts your device in Recovery mode, you can do a Wipe-Factory-Reset from there. Use volume up/down buttons to navigate and press Power button to select. Be careful and don't mess with other options or you may brick your phone.
5. Knocking the Touchscreen (Not recommended) Remove the Screen Protector on your Android device if present. Now, gently knock every corner of your touchscreen to realign it. Sometimes continuous phone drops cause screen digitizer cable to loses its connection to device motherboard however, its a rare case.
If you are still unable to make touchscreen work maybe its time to claim warranty, Its a lengthy process but works. Also, post comments below to share other tips not mentioned in this article.
May 29, 2015 | Cell Phones
Lg t515 touchscreen not working
method 1:remove battery and then again restart your mob.
method 2:make a reset by 3845#*515#.see if it work or not.
method 3:you can try formatting your mob by pc.
if none the above method work then get some help from lg service centre.
Nov 08, 2012 | LG T515 Unlocked Dual Sim Phone
I have a samsung gt s5233 w edge and the touchscreen has failed. the left and right part of the screen is not functioning anymore. but when i press at the center, the right side of the screen activates....
check the conector of the touch, if the touchscreen connector is not connected properly just unconnect and connect properly ,if it does not work buy a touchscreen.
Mar 13, 2011 | Samsung Star GT-S5233 Cell Phone
I have Samsung Corby s3653 touch screen phone, some times i touch the screen to open menu then it doesn't work. can you tell me why?
.@to all who have problem with the touchscreen
things you should do first.
1. Remove the sim card and Memory card.
2. Your unit should have fully charge battery.
Procedure in updating the phone.
1. Turn- on your S3653 W
2. Touch the keypad
3. Enter *#2665#
4. touch the 1
5. Wait for few minutes
6. Done.
This procedure is for S3653W only.
What the procedure will do is..
This will update the firmware from X08 to X09 which will automatically fix the touchscreen issue.
Jun 14, 2010 | Cell Phones
TOUCHSCREEN NOT WORKING
3 things you can do :
1. restarting the phone
2. restoring the phone via your computer
3. replace the touchscreen
May 19, 2010 | Apple iPhone Smartphone
Dropped iphone with WHITE Screen
Hi
There might be a Flex cable that disconnected in the phone, you will need to bring it to a cell phone shop or apple to have a look at it.
David
CellUnlock.net
Feb 25, 2009 | Apple iPhone 3G Black Smartphone
My touchscreen wont work
switch off and lev for haf hr and restart it wil workk
Nov 11, 2008 | Apple iPhone Smartphone
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Lesley Cameron
Lesley Cameron
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
