Question about Intel D845GVSR Motherboard
I am attached the mother Bord to the moniter but the VGA could no
    President:
  • 739 Answers
- remove all pci card. ide or sata cable and all connection from cd rom, hard disk, floppy drive.
- check your ram. ( scrub with rubber and broom your ram slot with brush.( or troubleshut with new one) and then restore to ram slot.
if that problems still appear.
- troubleshut your buildin display with the good display card(new display card)
if that problem is still appear.
- troubleshut your power supply with the new one.
if that problems is still appear.
- troubleshut your processor with the new one but speed of your processor must be same.but if your dont have same speed processor, your can try useing the processor supported by motherboard.
If your was do all the tip but your computer still no display.
i recomended your change to new motherboard support by all your hardware.
hope this tip can help your problems....
Posted on Jul 16, 2010
Turn on my computer, I can hear the fans, no beep noise upon starting. Screen says no signal found. I tried other monitor cables and monitor. No dice.
one of 2 things is happening a) if you have changed the cord and tried other moniters then the display port beit vga or dvi on you computer is broken you will either if you have agraphics card already installed then replace that but if you have no dedicated grapichs card you need to replace the mother bord
B) check your moniter to see if there is a source button if there is then push it to see if the image comes up repeat up to 3 times
ps: if you have a dedicated graphics card look at the back of you computer and if there are 2 different display ports be it dvi or vga (google image the terms "vga port" and "dvi port" to see what they look like) then plug it into the other on to see if the graphics card is broken
May 02, 2011 | Sony VAIO PCV-RZ56G PC Desktop
I have asus P5SD2-VM mother bord. This mother bord dose not support graphic why? It is supported windows 7 or not.
Hello you can try the vista driver from here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/#download
Click on vga and select global for download
Unzip the file before installation
Good luck
Jan 03, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No vga why? matsonic NS9147C
change the ram then try other wise check the mother board
Oct 10, 2009 | Computers & Internet
Moniter Data Cable Pin Connections
Download the user's manual. Usually such information is given there.
Jul 17, 2009 | Zerus Intel Desktop Board D815EEA...
Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Jul 04, 2009 | E-Machines eMachines Desktop PC
Hello i want the VGA (DISPLAY drivers of VIA mother Bord of proccersor series VT8237 how could i get it
Hi rocky5517,
The VT8237 is the southbridge chipset, which doens't tell what kind of VGA does your motherboard is inbuild with.
Anyway, you can try this download below, as normally the VT8237 with come together with K8M800 / K8N800
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1160&SubCatID=109
Good luck.
Don't forget to rate my solution.
Jan 14, 2009 | Computers & Internet
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Help about driver and softwera
which monitor you are using ...?
you mean you need the graphics driver or the monitor driver itself reply clearly i will get you the links...
and also tell me the model of the monitor if it is monitor driver & motherboard details if it is graphics driver ....
i am always here to assist you ..
reply me soon
Apr 07, 2008 | Mitsubishi Diamond Pro 900U 19" CRT...
Intel D845GVSR Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
