Question about Pioneer SD-641HD5 64" Rear Projection Television
Need to replace front screen. can i do this from the front? can i purchase this front screen material from anywhere other than pioneer
  • Pioneer Master
  • 5,138 Answers
Try finding one on Ebay under TV Parts ,Electronics and Try Encompass Parts Distribution type in your Model number and see if they are listing Screen replacement or call 1-800-638-3328
You can also Call local TV Shops to ask do they have a good used one for sale.
Posted on Jul 10, 2010
Where to purchase new or vg cond used remote.
If I need a Pioneer remote for a hard Disc Video Recorder I look at ebay first then the on line major remote suppliers. You can often get a good remote for $20-$35 at eBay the replacement places want $150 for not to mention many of the replacement remotes for older offered units are some sort of replacement unit which does not work as well as the real thing.
I'm in the process of repairing a Pioneer DVD Recorder remote it is done by removing five screws (including three hidden under the battery compartment cover) gentily separating the unit and taking out the soft pad. The contacts on the bottom of the pad were coated with conductive material so when you push the button the circuit is completed. Over time this material wears off so you have to push harder and harder and finally it does not work.
You can buy conductive paint on eBay and clean and repaint the bottom of the contacts which fixes this most of the time. Your fault may be a bad board in the remote but more often it is just the lack of a conductive coating on the bottom contact area of the button.
If you can't find the remote you need try to fix yours as I have noted it is worth the hassle. I recently found a remote for an arcane Sony MD Recorder for $2 at esale I balked at paying $65 for on ebay so if you are patient an live in a metro area with a lot of people donating to resale this might be another possiblity.
I hope this helps you...
Jul 19, 2013 | Pioneer DVR-520H DVD Recorder
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
I recently purchased a Pioneer SC-07 in North America(110v/60Hz) and need to convert it to use in Australia (240/50Hz) Am I able to purchase power supply to make this happen?
You need to locate a power converter. This is basically a trqansformer that will convert the 240V system into a 110V system. These are generally available anywhere where travel supplies are sold. You can also contact Pioneer and see if they have a conversion kit which would require the replacement or alteration of the internal transformer on the unit.
Dan
Nov 09, 2009 | Pioneer Audio Players & Recorders
Pioneer SD-T5022 Broke Screen
Call your local TV repair shops ask if they have any used screens ,From sets junked out. most shops sell them 100.00 or little more.order new from factory 500.00 Good Luck with your hunt .ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
PIoneer SD-643HD5
yes ,you need to replace both STK392-110s,or 120s,i always upgrade to STK392-180s.These are your convergence ics and you do need a service techician in order to fix this". after replacing both ics you have to realine complete convergence your looking at anywhere from 285.00 -350.00 depends on labor.one lady on here was told cost of repair on her set was 700.00 she has same problem.thats where she lives different prices from state to state.
Jan 26, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Replacing rear projection glass on Pioneer Pro-620HD
1)Pioneer entry is through the front,as you already found out.
The service manual will show you.......
2)Remove lower front speaker grill
3)Remove screen frame only
4)Choose left or right side to remove rail to access screens
5)CAREFULLY slide screens out to expose interior
6)Replace mirror and wipe off RGB lens caps
7)Reassemble .......................go slow,.............T.
Jan 25, 2008 | Pioneer PRO-620HD 58" Rear Projection...
AVIC X1
tune the station then press & hold the number you want it stored on...
If it bleeps and looks like it is stored. then you turn the ign off & you loose them again...
Then you should check the constant 12v & the Ign 12v as they may need swapping.
Nov 13, 2007 | Pioneer GPS AVIC-X1 car radio
Pioneer SD-641HD5 64" Rear Projection Television Logo
69 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
