Symbol MC70 - datawedge v2.01.02 - Won't read smaller bar codes. It reads the larger ones fine. Settings appear to be correct.
bluegreenash
  • 661 Answers
SOURCE: Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Posted on Jul 26, 2007
  • 13 Answers
SOURCE: Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Posted on Sep 09, 2008
  • 18 Answers
SOURCE: Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Posted on Apr 02, 2009
  • 6 Answers
SOURCE: Symbol LS 9100 does not transmit data
Have a look at the HOST setting in your defaults. I set one of these to default and had the same result. I'm guessing it's because the HOST is blank on Default settings.
Posted on Dec 09, 2009
kganoe
  • 42 Answers
SOURCE: I installed Datawedge.exe in my MC75 device.
We have set up many of these device with Datawedge. The configuration depends on what type of barcodes you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
Posted on Mar 17, 2010
After i scan with mc70 i have to press enter
Try configuring ScanWedge/DataWedge (it should be running).
  • Open the app
  • Click on the icon and on the menu select Config > Setup
  • Select 'Send ENTER key after suffix'
  • Click the 'OK' button
That should be it..
Jay
bb87eb9b-28f2-4b6a-a057-6937ebfe690b.gif 095d25dd-2241-46a9-a130-39a63c08239e.jpg
Jan 21, 2014 | Symbol MC70
ı have mc 7090 using windows mobile 6.1 ı use datawedge 3.2.4 ı want o scan code 128 type barcodes but its not reading. I was using earlier 2.0.2 version and checked symbologies...
Hello Osman, in the default settings of datawedge is an issue with barcode length for code128. Please check it and setup the specific length, that you want to use.
Klick on the DataWedge icon, select Standard Configurations, go to Scanner, Decoders, Code128 and select the min and max value.
Oct 29, 2010 | Symbol MC70 Barcode Scanner
The imager or scanner on my MC70 will not scan a bar code.
Do you have any software on the MC70 to use the scanner. You can use Datawedge if your software does not integrate into the device directly.
You can download the software from devzone.symbol.com.
Oct 27, 2010 | Symbol MC70
Barcode scanner for symbol MC70 is not working. The red beam shows when the button is pressed but when I scan a barcode nothing happens. Thanks, Pari Benson
Hello is_bsp,
which scanning application are you using? You could test the functionality by installing the manufacturer's application called DataWedge, provided here for download http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12743&sliceId=&dialogID=190394078&stateId=1%200%20190388513
Sep 03, 2010 | Symbol MC70
MC70 Scanner does not fire the scan ray every time the button is depressed. Also not scanning when it does fire.
If you are using Datawedge as your scanning applicaiton then the scanning varies depending on teh setting and what type of barcoeds you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
Mar 17, 2010 | Symbol MC70 Barcode Scanner
Is datawedge block the ability to use the camara
no, datawedge does not block the camera on the mc55, but you will need to load the camera file from support.symbol.com
if you need additional information please let me know,
Kim Ganoe
kganoe@datexcorp.com
Jul 07, 2009 | Symbol MC70
Can't use scanner
You will need to download an application from www.symbol.com called DATAWEDGE. It is free and very easy to use. This application will enable you to scan on to any other application on your MC70.
Apr 22, 2009 | Symbol MOTOROLA MC70 WWAN EGPRS WLAN...
Datawedge blocks the camera
The camera and scanner on the MC55xx share the same interrupt. While Datawedge 3.x is running, it has control of both devices and causes the behavior you're seeing. If you stop Datawedge before starting up the camera app (for example), it'll work just fine.
Why Motorola thought interrupt sharing for two commonly used hardware devices is a good idea, I'll never know.
Mar 31, 2009 | Symbol MC70
M70 Barcode canner ussing problem
i has mc70 barcode scanner .My problem is can not scan the barcode smoothly i need scan one barcode using 15 min then the thing scanned .Please help and advise ?
Feb 04, 2009 | Symbol MC70
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
