Question about Dishwashers
We have a model MDB5130. All the indicator lights are flashing and dishwasher will not run. What do we do?
  • Dishwashers Master
  • 5,603 Answers
First try cycling the power off at the breaker for 1 minute to reset the controller and then see if it works.
Posted on Jul 10, 2010
My Samsung Dishwasher keeps flipping cycles during the course of its run. I set it to "normal" and it ends up on "delicate". Dishes seem to be clean, but are still wet after the 2 hour run time. Help...
I'll bet that Delicate light is flashing, which is actually indicating an error. You didn't mention your model number, but in most Samsung dishwashers I'm familiar with, that light indicates a Drain Error. You may have something hard caught in the impeller of your drain pump, or you might have a bad ECS sensor. In any case, it's time to call a dishwasher repair technician. For Samsung dishwashers, I recommend calling Sears Service (1-800-4MY-HOME or 1-800-469-4663).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 26, 2014 | Samsung Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Salt (PC) light is flashing
Miele dishwashers have a built-in water softener. I suspect the unit is indicating that the dishwasher softener salt is low or needs to be replenished.
Which model dishwasher do you have? http://www.mieleusa.com/products/modelsg5000.asp?cat=2&menu_id=1&oT=125&active=Our%20Products&subm=Home%20Appliances&thirdL=Dishwashers&fourthL=Products lists a number of their dishwashers and has the manuals for them. Click on the model and scroll down. Click on the Manuals tab. (Click on the Retired models if your dishwasher isn't on the first page.)
I hope this helps.
Apr 10, 2012 | Miele Dishwashers
Hi, our ariston dishwasher has stopped before the cycle finished and the water has not drained out. There are 2 flashing lights - the brush emblem and the spray ' on a tilt' emblem (the 2 on the...
Error messages.
The dishwasher is equipped with a
safety system which is able to
detect any operating anomalies.
These anomalies are signalled by
the rapid flashing of one of the
wash cycle indicator lights M.
If the indicator light for the soak
cycle flashes (see wash cycle table),
cancel the wash cycle by following
the instructions indicated in the
"Modifying a wash cycle in
progress" paragraph on page 4.
Now check whether there is any
water in the mains supply and that
the tap is turned on; if the error
message persists, then call for
technical assistance, indicating
which message appeared.
If the indicator light for any wash
cycle apart from the soak cycle
flashes rapidly, turn the appliance
off and call for technical
assistance, indicating which
message appeared.
Troubleshooting
You have checked
everything, but the
dishwasher still doesn't
work and the problem
persists?
Call an authorised service centre
near you and remember to mention:
? the type of malfunction
? the model mark (Mod?.) and the
serial number (S/N?.) indicated on
the rating plate located on the inner
door, to one side.
If you need further help, reach me via phone at https://www.6ya.com/expert/kelley_9a924afdf232bd4d
Jan 14, 2018 | Hotpoint-Ariston LI 640 24 in Builtin...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
