Question about Brookstone AcoustiClear 3-CD System CD Player
Hi I have the Brookstone acousticclear 3cd system and i wanting to connect outdoor speakers to the unit....i bought the speaker selector the wire and I have the outdoor speakers but I can't figure out how to connect the speak selector from the main unit ? I have the sub woofer on the floor and can't seem to figure out where I would connect that piece to the speaker selector ? or any other suggestions please.....raul
3 Suggested Answers
  • 1340 Answers
SOURCE: Hello, I just bought a
As long as the wires had a clean connection on the right side,that is the proper troubleshooting with the correct answer.If you really want to try to fix it yourself or at least try here you go.I would like to know what kind of jack/hookup there is for this wire.You probably need a solder gun.63/37 is the best solder possible(but don't buy either yet).Disconnect all the wiring (obviously).Turn the player on and off to discharge the capacitors as much as possible.They may still hold a charge,but I've been "bitten" by those and it's no big deal.Unscrew the back.You may have to remove some more screws to inspect the solder on the board to the right channel jack.You may also need some small,I think they're called precision screwdrivers?I don't remember.I bought mine about 20 years ago.If there is a crack in the solder,a bad solder connection,or a break in the circuit line to the jack which is embedded in the board,that might be something.If the circuit connection embedded is broken it's can be fixed,kind of rigged,but not dangerous.You could also talk to ebay and tell them what happened if you don't want to try all this.I do not know their liability policies.Anyhow,please let me know what you end up doing.Good luck!Greg
Posted on Aug 06, 2010
SOURCE: I need a connector (CD to sub-woofer) for the Brookstone Wafer thin CD player with MP3.
www.stockcable.com carries what you are looking for. It's a 9 pin mini din male/male connector cable
part number R58190A-09
Posted on Jul 30, 2012
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
I need an AC adapter for outdoor speaker(497362p ) Whats the output V. requiered? Where I can buy it ?
Hello
The AC adaptor for your Brookstone is for [12V 2.5Amps]. You can get it from most of the electronic sparepart shops at your town. OK.
Jul 24, 2011 | Brookstone (497362) Main / Stereo Speaker
Hook up brookstone wireless outdoor speaker
You cannot add other brand speakers to Bose systems. You must purchase the Bose second zone speaker amp and speakers.
Apr 26, 2009 | Bose (321GS) System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
$150 wireless speaker
use a expanded module for input/output RCA ports, Radio Shack
Jun 15, 2008 | Brookstone Outdoor Wireless Speaker...
Brookstone Wireless Rechargeable Speakers with auto-tuning
its probably the interference with the routers. try getting internet by bypassing the router. much easier sound quality.
Jun 12, 2008 | Brookstone Outdoor Wireless Speaker...
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Speaker will not turn on
See if has a fuse anywhere. These are throw away items. It might be time.
mike
May 09, 2008 | Brookstone Outdoor Wireless Speaker...
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
