Question about Health & Beauty
I have a Qtronix Universal Specialty Control Module for my power wheelchair. When I turn it on it says "This UNIT IS LOCKED" and I cannot use my chair. Is there any way to correct this?
  • 6,826 Answers
I looked up the Qtronix Universal Specialty Control Module and I see that it costs $1200.
Contact Sunrise medical to see what can be done about 'This UNIT IS LOCKED.'
The manufacturer should have the procedure and code to unlock the unit.
Physically disabled people shouldn't be put into a situation where they bought something second hand and cannot use the features of the wheelchair.
I do think it's a good product, allows high level quadriplegics to use a non-joystick mouth control like that famous astrophysicist to control functions of a computer or a wheelchair.
Good luck to you..
Posted on Jul 10, 2010
  • scborgo Jul 10, 2010
    Do you have any suggestions to unlock the unit? Sunrise Medical offered me no assistance.
  • Duane Wong
    Duane Wong Jul 10, 2010
    I think that this is unfortunately an issue of Sunrise Medical not staffing their tech support department with the best and the brightest, and I also read, that Sunrise Medical lost a lot of money in stock value... recently.
    I am not prepared to unlocking a microprocessor controlled unit that I did not personally design or build.
    You see, I live in a small town of 5,000 where the technology industries seem to have forgotten.
    I mean, yes, there is a Walmart here, but there is no real industry like the Silicon Valley in the 1980s.
    Walmart sells a lot of high tech toys, but none are made here in Somerset, Penna.
    And, Penna. is a depressed state as far as funding, compared to say California.
Mpv 4 will not power up
You must follow the power. With a multimeter start at batteries, go to battery connections, connections into control module, out of control module and at controller.
You should have at least 12.6V on each battery and not below 25V for both. If you have readings lower, replace the batteries. If you get at least these readings, it should be the same V readings all the way through the system. When it is not, that is where the problem is.
Apr 02, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
QTRONIX joystick for a Quickie P200 wheelchair diagnostics
This is a very good question. You need to to take this issue up with Quickie. Here is there link. The main office is in the USA.
http://www.quickie.com/
Dec 12, 2007 | Video Game Consoles & Games
Pride jazzy select turns on but when you try to move the battery light flashes 8 times then turns off.
Appear to be a problem with you control system. Check joystick module and power module connections. Look for frayed and damaged wiring.
Mar 24, 2013 | Pride Jazzy Select 6 Indoor Power...
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
The electric wheelchair is flashing the locked symbol but we don't know how to unlock it so that it will work
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
May 20, 2010 | Invacare Pronto M51 Power Wheelchair
Somehow I have locked my Jazzy 6 Select Electric wheelchair. I know you need to push the trottle but I really don't know what to do.
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
Mar 20, 2010 | Pride Jazzy Select 6 Indoor Power...
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can't find where it plugs into...can anyone help
the wire with the fuse belongs to external light fetures (unit does not have. It was intended for future use for external ligts)
the two yellow lights endicate problme with batteries( too low) or the module controller.
3. Left motor Fault
9.Shark Module Faul
****two yellow lights*** Module problem
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
Any reputable dealer will have a PnG or Qutronix programmer that plugs into the chair in order to program the profiles. This dealer obviously does`nt know that. Call a different dealer.
Dec 12, 2007 | Saitek ST290 Joystick
Health & Beauty Logo
57 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
