Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
SWITCHING DEVICE SHORT-CIRCUIT 94-4311
COULD YOU PLEASE GIVE ME DETAILS OF THIS COMPONENT
IF ITS AVAILABLE IN BANGALORE, OR IS THERE A SUBSTITUTE
AVAILABLE?
THANKS
DARRYL
Do you know any reliable detective agency in Bangalore that works for employee investigations?
Yeah, I do know such a service in Bangalore, which the company I am currently working is using on a regular basis. Our company does use this service, every time during their hiring process, and this is a part of the security verification procedures of our company. Though this is a part of the procedures, it is carried out purely confidentially, without letting know, or giving any clues or hints to the employees about this. This is also considered to be one of the most reliable Detective agency in Bangalore. They have been working for our company for the past one year, and they scrap the exact details as we specify. After the investigation, they give the complete report of the details collected and also destroy the duplicate copy of the originals, after handing over the employee details to us. So I would like to say in short that the employee verification became a much easier task for my company with these services.
Apr 02, 2018 | Computers & Internet
Flyback transformer 14a001 substitute
what is the brand name of the set? If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given. You can get details from them. Search with the number of chroma IC used. It too will give you some details; I assume.
Good luck.
Jul 05, 2016 | Televison & Video
I have behringer fbq 1502 eqlizer, if we switch on the unit output indicater will blink with noice so please help me to solve this issue
Short circuited component/s at its main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 02, 2016 | Behringer Music
TV CUT OFF,CLICKING NOISE NOW & STANDBY BUTTON FLASHING
"Short circuit" protection section circuit detects a short circuit; most often with its main board; and shuts down the set immediately after switch ON; to prevent further damage to components. This is what happening with your TV. Contact any service technician.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your TV, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 16, 2015 | Televison & Video
What price I can expect 3 BHK flat in Alpine Eco in Bangalore?
Flat in Alpine Eco can be available from 40 Lakhs for 3BHKL.
If you want more information about it, you can visit Flats in Whitefield.
This online platform would provide you an amazing collection of apartments in 1BHK, 2BHK, 3BHK, and 4BHK at a most efficient price. The surroundings are best with all facilities and flats are developed by most famous builders of Bangalore.
mahadevapura_outer_ring_road_bangalore_106864099444740080-keeshhx3wfdoj25lkbjhkyj2-1-0.jpg
Dec 01, 2014 | The Computers & Internet
I have an Apex pf3230 32" TV that recently shut off, no power besides a slight clicking noise. The noise seems to be coming from a large component with a solid copper band about 3/4" wide... on said...
The short circuit protection circuit inside the set; detects a short circuit [shorted component/s]. The circuit shuts down the set; to prevent further damage to components. That is happening here. The sound you hear is from a cut of relay; which in turn switches off the set. Contact any service technician to detect the fault. Never switch the TV "ON"; until this fault has been rectified. It might make things worse. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 30, 2014 | Televison & Video
Hitachi 32ld8600 keeps blowing fuses
There should be a short circuit at the main power supply regulator board. Check all the rectifier diodes and other components. Check the switching device for short. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
I have a sansui tv set with a power problem . MOSFET W11NB80 in the power section is completly blown . can t get it in the local market in kenya what is the equivalent value. its a crt television...
Hello
W11NB80 is an N-channel 800V-0.65ohm - 11A - rated Metal Oxide Semiconductor Field Effect Transistor [MOSFET]. You can use the folowing substitutions for it
[ 11NM-80, 12NK-80 & 10NC-802]. All of these are its equalent substitutions.
Before replacing the mosfet, check the entire power supply secion for any short circuit, or zener diodes faults. If any of the zener diodes are fused, it will run out the MOSET you sumstitue again. Check it keenly. Unsolder one end of each component, lifit it up a liile from the circuit board and check. Especially zener diodes must not show any leak in 100Kohms range. It is best to replace them all I suggests.
I don't know about its availability in Keniya, yet you try to get it from any electronic spare part shops. f feels any difficulty in getting the same contact [E-Bay] site, they will reach you the exact component at your doorstep. Ok.
Dec 28, 2010 | Sansui DTV2760 27" TV
Need to replace transistor. No pin out available for red, black and blue wires, please let me know which one goes to transistor's K, A and G.
If the devce you are referring to has K (Cathode) A (Anode) G (Gate) then you are referring to a SCR and not a transistor!
SCR are typically used in AC light dimmer and motor speed control.
You should always use the same or higher rated equivalent component: a Transistor (usually used in DC circuits) IS NOT a substitute for a SCR (usuallly used for AC circuits)!
PLEASE REMEMBER THAT YOU ARE DEALING WITH LETHAL AC MAIN VOLTAGE so unless you are familiar with both Electronics and Main powered devices, I would NOT recommend that you attempt this repair.
As a general rule, if you cannot identify what the original device was and where it originally came from on the circuit board, I would leave it to a qualified person.
Hope it helps you make the right decision.
Jan 14, 2010 | Bosch 1 - 1/8" Reciprocating Saw RS5
I own a JVC UX-G37 Micro Component System. The display has stopped working and there are no lights at all on the display except the Standby light. Apart from that there is no other problem with the system.
Check CP901 (ICP-N10-T) in power the supply board. The normal state is a conductive device, in case of protection, it becames an open circuit. Substitute it by a new one.
Sep 21, 2008 | JVC Audio Players & Recorders
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
315 people viewed this question
Top APC Computers & Internet Experts
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
