Question about Vacuums
My honda gx390 pressure washer is not starting. It is backfireing through the carb. Will run if I pull enough sputters them might kick in and run then will die. I have cleaned the carb & float bowl and changed the oit so it is up to leavel and seem to have spark but could be better spark. It was running (allthough not well ran out of gas and then I filled it up and this is what I have. Thanks for any help.
    Top Expert:
  • Vacuums Master
  • 12,962 Answers
Those carbs are not expensive - try a new one.
Posted on Jul 26, 2017
3 Suggested Answers
  • 3917 Answers
SOURCE: MTD Yard Machine, 3.5HP /
Have you checked the primers on both of these units? It is possible that the primers are not putting enough fuel into the system. Look for holes or torn edges. Depending on the engine models. Also it can be lack of necessary vacuum and compression in the combustion chamber. But most probably it is a carb issue. It is suggested to rebuild the carburetor. Also when you clean the carburetor make sure the jet screws are seated in proper position in the way when you put the jets back in, you know to lightly seat them first and then turn them back out to their correct position before you started.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Posted on May 24, 2011
  • 7482 Answers
SOURCE: At first when I tried
Hi tifix1...
Yes, that could cause your problem.
I will offer a few more things to check and repair/replace, maybe there is a few things that you missed.
Please take time to rate me
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Posted on Aug 23, 2011
What do I do
Switch has gone bad. You can open the switch up and clean with electrical contact cleaner to see if it helps. If not jump the wires to the run position by hand. If it runs the switch needs replaced.
Jul 21, 2014 | Keihin 1993-2007 Honda XR650L FCR41...
I have a Honda 93 XR650L motorcycle. I can't get it to run. It will start for a second and then die. I have put a new regulator rectifier and i don't know where to go from here. I do know that when i try...
start with the most simple things first. fuel filter blocked? carburettor getting enough fuel or not enough? does it puff out any black smoke when starting for that second, will give indication of over fuelling if not.. try manually putting a little petrol into the carburettor might not be getting enough gas?
2000 chevy silverado v6 vortec 4.8 have to hold throttle wide open to start while engine running has loss of power on acceleration an backfire from exhaust system an plugs are fould out with carbon an has...
Hi David, it's Jack at Dyson.
I can see you're not looking for help with a Dyson vacuum, and if you haven't done so already you may want to resubmit your query under the correct category to be sure of receiving some expert advice.
Good like with resolving your query!
Mar 17, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Fault Nilfisk Alto pressure washer
see the diagram and repair swtich:
May 14, 2012 | Vacuums
Fix euro pro 1300 psi pressure washer
I would take it to a proper repair facility (Sears. I used to work at their Harrisburg Repair Center). They are trained to work on equipment like this.
May 05, 2012 | Vacuums
My Simoniz S1900 pressure washer "pulses" on and off when I turn it on and pull the trigger. I have purged the pump of air as pre the company's video but nothing helps.
One thing to check is that the hose connected to it isn't collapsing and cutting off the water supply. Make sure plenty of water pressure and volume at hose as well.
May 23, 2011 | Vacuums
Snowblower when running it backfires nonstop
THE MOST LOGICAL CAUSE IS THE CARBURATOR NEEDS REBUILT. IT IS DIRTY AND RESTRICTING FUEL AND AIR FLOW. HAVE A GOOD DAY! it may even be as simple as a new spark plug. try turning the fuel adjustment on carb, all the way in and back it out 1-1/2 turns. the idle screw should be screwed all the way in and backed out 1 turn. if it has a screw on bottom of float bowl or carb, it is the high speed jet, try adjusting it, in or out.
Nov 27, 2010 | Craftsman Vacuums
Craftsman Electric Pressure Washer 1800 psi. Start then runs for a minute then stops.
The motor overload / thermal protection is likely the cause. Check your hose and wand / nozzle for restrictions. Is this the same hose and wand that it shipped with, or is it from another machine?
Your local Sears store can get you a user manual and diagram for our pressure washer for further troubleshooting.
Jun 27, 2010 | Vacuums
84 kawasaki voyager bike has sat up for 2 years. has low spark & fuel but will not start once in awhile it will pop or back fire.
fuel problem :
first try starting fluid spray can. if runs very short time, then carburetors are gummed up...need re-jetting or remove and buy a gallon of carb solvent and soak carbs for a day then shake out vigorously then air blow dry with compressor then retry
low spark...could be dirty plugs-clean them- or worse may be bad spark unit...try removing spark unit and pull away from chassis then re-attach wires and try....if ok spark, then unit is grounding out to chassis on rear mounting surface...look at back for small cracks in black plastic on unit.
Mar 21, 2008 | Vacuums
Vacuums Logo
271 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
