Question about Black & Decker BL-3900 Blender
I have a bl 2900 blender which has stopped working in the middle of blending. waited for sometime to cool but couldn't get it to run after cooling down. Suggestions?
  • 619 Answers
SOURCE: blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Posted on Jan 14, 2008
  • 89 Answers
SOURCE: KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: the blades stopped turning in the middle of
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Posted on Jan 15, 2010
SOURCE: The coleman rechargable blender not blending
Rechargeable Portable Blender Model No. 850-870 not blending
Posted on Sep 12, 2010
SOURCE: My blender stopped blending and
Mine also stops and I just let it sit a few min and it gos a gane
Posted on Apr 06, 2011
Motor stopped during usage will it reset
Check power to where you had it plugged in. Maybe it is the switch on the unit or the motor has died. Then replace the unit.
May 28, 2014 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Ninja stopped working
Our Ninja 1100 also stopped during blending.
We set it aside and chopped manually.
Next day tried it again - it works.
Reason: motor probably has overheating protection. Must wait until motor cools down enough to re-start. So don't overload or overwork it.
Feb 27, 2014 | NINJA Blenders
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
When I make a frappacino I get lots of foam instead a slushie drink
You're blending at a high speed and air is getting introduced. Try a slow blend speed. This should solve your issue.
Jul 24, 2011 | Vitamix 5000 Work Top Blender
The pulse light is blinking, but the blender will not work
This worked for me - only took about 5 minutes (the amount of time it took for me to google Black & Decker and search through their FAQ)
Q. My blender stopped in the middle of blending. What happened?
A. Your blender has a motor overheat protection system that will automatically shut off the blender when it has been running too long with a heavy load. If this happens, unplug the blender and wait 10-15 minutes to allow the motor to cool down. Plug in the blender and resume blending.
May 28, 2010 | Black & Decker BL1900R Blender
I am unable to get the blending cup out of my Bella Cucina Rocket blender. I recently purchased this have and only used this a few times including once just before the ''cup'' stuck. It appears to have...
Hi! I just had the same problem and actually called the service number that came with the rocket blender. The lady on the phone said that the plastic cup must have expanded (from heat), and to stick it in the refrigerator for 24 hours until the plastic shrinks back down to normal. After the 24 hours the cup should be able to come off. Kind of makes sense, but I hope it works!
May 11, 2010 | Bella Cucina 13330 Rocket Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Unit began smoking and smelled hot
If this was a recent purchase for which you have a receipt, return it to the store immediately while you still can. If it is beyond the store's return policy, but purchased less than one year ago (most times you will still need a receipt), call Black and Decker to get in-warranty service/replacement.
In fact, call Black and Decker anyways - if the BL5000 was manufactured between Dec.2003 and Jan.2005 (highly possible if it was marked on clearance), the blade assemblies were recalled. here is the recall notice:
http://www.blackanddeckerappliances.net/safetyrecall2.html
If it is out of warranty, let the blender cool for an hour. Then remove the blender jar, plug in the base, and see if it will spin with nothing attached to it. See if it smokes if left on for 1 full minute - don't let it run longer than one minute.
If it doesn't smoke, let it cool for an additional 20 minutes. Then remove and then reassemble the blade assembly, gasket, etc., collar, jar, etc. Try blending. If it smokes while blending, order a new blade assembly and gasket (usually they come packaged together - around $20 or so). Once the new blade assembly/gasket arrives, try blending again. If it doesn't smoke, you're probably good to go. If it does smoke, you have a more serious issue.
All of this is going to take time and money if it is out-of-warranty. If you have deemed that the blender is worth more than $50 for a new one, let me know.
Mar 26, 2009 | Black & Decker BL5000 ProBlend Work Top...
KITCHENAIDE BLENDER
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Black & Decker BL-3900 Blender Logo
81 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
