Replacing an 8ohm 50DB potentiometer made by alps for the ess amt 1a crossover would a 8ohm 15 watt potentiometer be the same beast
2 Suggested Answers
  • 3 Answers
SOURCE: behringer 1508 into 2 300 watt 8ohm speakers will
you got to stating your processor, the amp, the preamp, the speakers type you own.  Without that, its hard to inform accuracy info for your request.
Posted on Aug 31, 2009
Loaded with 2-10" scorpions(8ohm)each, and a 18" black widow (?ohm)...can i load a 15" black widow(8ohm)using the same crossover Part# 90890170
I would assume that the 18" was a 4 ohm if the two 10" were 8 each. Though it might work in a pinch, the crossover point would be different and the balance between the speakers would probably be different as well. It's suggest calling Peasvey Customer Service to get the best answer. Here is their link-
Peavey com
Apr 19, 2016 | Music
I have a Crate V16 -15 watt Amp w/12"-16 ohm speaker. Can I use a 8ohm speaker instead ?? Thanks
According to the manual, it needs a 16 ohm minimum load, so no, you best not use an 8 ohm speaker.
Nov 13, 2014 | Music
Samson auro d415
do not use chemicals!
the best you can do is to remove the volume pot and try your dentist or optometrist for an ultrasonic cleaner. 5 minutes should be fine.
If that doesn't help replace the potentiometer
Apr 18, 2014 | Samson Auro D415 Active PA Cabinet - 400...
Schematic for tascam cd-rw900sl
It looks similar to ALPS RK09K12xxxx (at least on my Yamaha E-Violin)
This reference can be found on Alps web site and can be acquired in some (old) parts suppliers.
Good luck.
Dec 06, 2012 | Tascam CDD Computers & Internet
What are the specifications for audiobahn a2200hcx amplifier
The specs are as follows:
RMS Power Rating:
200 watts x 2 chan. @ 4 ohms
400 watts x 2 chan. @ 2 ohms
800 watts x 2 chan. @ 1 ohm
• Bridged:
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
1600 watts x 1 chan. @ 1 ohm
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Apr 15, 2011 | Car Audio & Video
I have a old NAD 1300 pre amp. I need to replace the volume rheostat where can i buy the part?
Hi, for the price of servisol you may as well buy a brand new pot. The nad uses a dual carbon pot. Any electronics shop should have one.
Is it a pcb mounted type or one with loot solder tags?
A couple of quid, but if you want to upgrade, then spend around a tenner and get an alps conductive plastic pot.
Try this:-
http://www.rapidonline.com/sku/Electronic-Components/Resistors-Potentiometer/Control-Potentiometers/Professional-audio-potentiometer/65228/66-0225
OR:-
http://www.maplin.co.uk/Module.aspx?moduleno=2207
Have a look on ebay, there should be loads.
Just found this mod.
http://www.diyaudio.com/forums/attachments/solid-state/69062-replacing-nad-1300-volume-balance-pot-nadmods.jpg
If you need more help, give us a shout and i'll try harder :)
Regards - Anthony
Feb 11, 2010 | NAD C320 2-Channel Amplifier
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
Behringer 1508 into 2 300 watt 8ohm speakers will
Aug 31, 2009 | Audio Players & Recorders
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
116 people viewed this question
 Grubhead
Grubhead
