Question about Cameras
Hi I am Nats, I accidentaly dropped my camera when i was trying to take a pic and it just stop workin and the lens are stucked. it shows lens error and restart camera. What can I do? Please help.! Thanks so much!!! Nats
  • sim9919 Jul 10, 2010
    not yet
    President:
  • 2,185 Answers
Hi there Nats,
When you dropped the camera, there must have been a grit of sand or a dirt built up that caused the lens from retracting, thus it is giving you the "lens error". Here is what you try to do. Hold your camera on your right hand with its lens facing the ground. Now, turn on the camera by pressing the ON button while tapping the camera's base on your left palm. Do this a few times like you were trying to take out the dirt off the camera's lens.
Also try to use a canned air or blower to blow in the sides around the lens barrel to blow off sand that might be jamming the lens.
Please let me know if this works or not so I could advice you other solutions.
Posted on Jul 10, 2010
    I tried but it still doesnt work. now it has the zzzzzz... sound whenever i try to on and off. any other solutions? I m bout to go on vacation next week i hope it works soon. thanks so much for helping.
  • virtualhost
    virtualhost Jul 10, 2010
    Hi there Nats,
    If you turn on the camera, does it seem to be moving its lens like giving slight movements? like its trying to retract out? Try other solutions like the following:
    1. Lay the camera on the table with the lens facing up. Now press and press and hold the shutter button and the power ON button simultaneously. The camera will eventually try to focus automatically while
    the lens is retracting out.
    2. If you can notice that the lens barrel appears has bent or crooked, try rotating the lens by forcing it out or pulling and twisting the lens barrel pressing the power button.
    3. Now as you said there is a zzzzz sound while trying to turn on the camera, the lens barrel guide may be misaligned due to the fall. Look for uneven gaps around the lens and then using your finger, gently push one side at a time. Try to listen closely for any click sound as you push the side or the lens barrel one at a time. If you heard the click, try turning on the camera again.
Is there a reset for the lumix dmc lz2
my camera works but it has a black screen fore a pick but show the menu and stuff
Nov 05, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens stuck in the out postion
Did you try taking out the batteries out for a few hours to reset the camera? Did you eliminate the possibility that the batteries can be the cause of your problem?
Dec 26, 2007 | Pentax Optio M20 Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
I have a canon powershot SD850 IS...it was dropped accidentaly and its not starting n says lens error restart camera...how to fix it??
Very difficult to repair at home due to having to remove most of the camera insides to get to the lens mechanism. The lens then needs to be opened in a dust free enviroment and repaired. Your best bet is a local independent repair shop.
Nov 03, 2010 | Canon Cameras
I dropped my Polaroid i532 and now the lens wont
hi,
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Thanks....
Jul 07, 2010 | Polaroid i532 Digital Camera
My baby nephew dropped my camera on the beach and now it has some sand stuck in it and has stopped working. can this be fixed? p.s it turns on but no longer lets me take pics.
Hi!
I believe there's sand inside the lens or stabilizer - the lens unit has to be taken apart and cleaned by a professional. It's a hardware fault, not software so I'm afraid you will have to give it to a local repair shop or Kodak service center and let them clean it.
I work in Kodak service center.
Tom
Oct 09, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
