Question about Motorola Mobility i760 Cellular Phone
My screen is totally white, even after I power down and take the battery out, but the screen on the outside of the phone is still working, motorola i760.
    Sergeant:
  • 164 Answers
Hey guys, i'm sorry but i have some bad news :(
This black screen of death which you have all been experienceing has been a problem of many different phones and all of them have the same cause. It is a manufacturer defect in the phone which pretty much has screwed up the software inside. Sometimes it may take a while for this problem to be come apparent (such as in my case it took nearly a month). I have done hours of research, and there was only one solution. The phone needs to be replaced.
Sprint has told me that no customer will be charged for replacing the phone (insurance or not) because it is a manufacturer / software problem. the only difficulty is that without phone insurance, it may take a few weeks to get your new phone sent to you from Sprint. With insurance, you can just walk into a Service center and get ur phone replaced on the spot.
One major pain with this problem is that all phone numbers and data (except on the mini sd card) is erased or unreachable.
Sorry about the bad news, but i hope this helps everybody getting this same problem no matter what the phone.
Thanks
Posted on Jul 10, 2010
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
Motorola Rival Keeps Restarting Itself
My rival has this problem now. The last two I went through both had displays go bad and render nothing but white screens. I only got the first one about a year and a half ago. The only permanent solution is to buy a non-motorola phone. The rival is a total lemon.
Mar 01, 2010 | Motorola Mobility Rival A455 Cell Phone
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola krazr phone
First suggestion is that you remove the battery totally for a few minutes. If that doesnt work I'd suggest you do a master reset. Go to settings, initial set up and scroll down to master reset. Hope this helps
Sep 14, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility i760 Cellular Phone Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
