Question about Scosche Industries EFX Amplifier Wiring Kit 8-gauge w/Patch Cord Car Audio Amplifier
How do you hook your compacitor to your amp - Scosche Industries EFX Amplifier Wiring Kit 8-gauge w/Patch Cord Car Audio Amplifier
  • 58 Answers
Take your main power/ground leads,put them on the capacitors terminals,then take how ever many feet of wire needed to go to your amp,put the ground on ground and power on power.
Posted on Jul 18, 2010
Red light will not go off on my daul amp 800 watt I have it hooked up to a 1600 watt compacitor
The compactor probably crushed it! No clue as to what you are asking
Apr 16, 2015 | Car Audio & Video
Duotherm a/c 59516.331 p/n 70130997 need to know what is attached to the top of compacitor...need to know the mfd for run compacitor as well as start compacitor. think run compacitor is=35.5 @ 370..
The wires attached to any component is shown on the wiring diagram. Use the same values that's printed on the capacitors, when replacing them. Call the manufacturer for any missing technical information.
Aug 27, 2013 | Heating & Cooling
My orion 2150sx is smoking when powered
No some one did not have the speakers hooked up properly ,End probably went under the OHM,Rateing for the amp, Or use the wrong OHM SUb on it, OR if they used a Dual voice coil sub,Didn,t have it wired up Properly.
Oct 30, 2012 | Car Audio & Video
Lamar vibe286 car audio amplifier has a blown compacitor
if a cap has blown then the mos-fet's has probably gone down and to be honest there will be a lot of other possibility, how did it happen?
Apr 11, 2012 | Lanzar VIBE286 Car Audio Amplifier
The Ice Machine is pulling 40 - 50+ Amps on compressor startup, after 5 - 10 secs it trips the breaker. WHat could this be and is it easily corrected.
sounds like you need to change compacitor on compressor or your compressor needs replaced i would change compacitor first and if not helping then change compressor even if you buy compacitor and it doesnt help you still need to have a new one for the new compressor
Jun 20, 2011 | Franklin Industries Franklin Chef Ice Cube...
I have a 98 mustang with the mach 460 system in it. I am trying to add a subwoofer and amp to the car and i can not find the speaker wire to splice into so that i can get bass out of my memphis audio...
Okay you will not find a wire to splice into. Assuming that you have an aftermarket Head unit, your gonna need to hook those rca cables in the back of the head unit (the red and white female inlets) and run those to the amplifier, afterwhich can you run at least 6 to 4 guage wire (available at walmart) from the amp to the subwoofer. Now make sure you buy a power compacitor to handle the extra juice needed to run that amp, which is alot cheeper than buying an extra battery and running that off your alternator (not a good idea by the way).
Oct 04, 2010 | Scosche Industries Car Audio & Video
No power after i unhooked the wire from amp, left wire uncovered at ends for couple days tried hooking them back up and no power now. is amp blown
if you unhooked the wire from the amp while the amp was on, you may have possibly blown a fuse, or mayb a transistor or compacitor inside the amp! easy fix, just find new transistors and compacitors and soilder them on after removing old ones!
May 03, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Should the wires coming from the run compacitor have power
The run capacitor is not a mechanical device, so the clicking that you are hearing is not actually coming from the capacitor. If you the wires going to the capacitor, (isolate the capacitor), you can check the microfarad rating of the capacitor to ensure it is still good using a multimeter. Hope this helps.
Apr 15, 2010 | Refrigerators
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Smoking Amp/Fuse Blowing
Sounds like you may have a shorted switching Transistor in the switch mode power supply causing a short to ground. If you are technical enough. Remove power remove cover and do a continuity test on the transistors on the heatsink. non of them should read zero resistance between the three legs. in all connection configuration you use to hook up your meter. If one or Two or even all of them do you must replace with proper part.
Aug 02, 2006 | Legacy LA838 Car Audio Amplifier
Scosche Industries EFX Amplifier Wiring Kit 8-gauge w/Patch Cord Car Audio Amplifier Logo
66 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
