Question about RCA 32V420T 32" TV
How do you get to the auxillary channels or the channel where the DVD player or video games would go? I have a DVD player hooked up to the TV, but it only goes from channels 2-69 with no auxillary/video channel or button.
  • cp3fromdaupt Jul 10, 2010
    By the way, i have a universal remote that i bought from radio shack. It does not have an imput button.
  • RCA Master
  • 5,343 Answers
Do you have the original remote? If you do, you need to press the input button (on the left below 7 and above the DVD controls). The external device must be on before you scroll through the available inputs. Unfortunately, I'm not sure if the OnScreen Menu has an option to toggle the Input (since there is a Menu button on the TV it would work around the issue).
A substitute remote that should access all of the TV features including the Input is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=32V420T&brand_pn=RCA_32V420T&mode=large&uuid=12787350637590
I hope this helps.
Posted on Jul 10, 2010
Testimonial: "thanks"
I can not get the tv to go back to channel 4 to watch reg tv after hooking up a Dvd player to it
Do you mean the gray CRT Durabrand from 2004? I had one of those exact ones myself recently with the remote and everything.
You need a remote control to go back to the regular channels if you're in Game or Video mode (like watching your DVD player); those inputs are entirely separate from the channels to the point that you can't use the channel left/right buttons to get out of there. In fact, before I got my remote, I couldn't even get INTO Game / Video mode; I had to use an RF modulator on channel 3. For the Durabrand 13", the remote unlocks much more out of the TV.
Jan 30, 2018 | Televison & Video
Rca j25420 (Older device)
Basic DVD player connections consist of three wires: Right audio (red), left audio (white), and video (yellow). These plug into corresponding connections on the rear of the TV. Your RCA TV may be so old it does not have these input connectors on the rear. Tne "game channel" you are attempting to find does not exist.
Dec 18, 2013 | Televison & Video
Channels will not program into tv so that my dvd player and Playstation2 will picture can be seen. I can hear both, but it TV is on wrong station and will not program in
You have a DVD player hooked etc to either channel three or four? Usually this equipment is connected into the Jacks on the rear of the set, that is to say hooked to a video input and not with the tuner, if hooked that way select the input with the remote for the set and see the picture....
Clarify how you are hooked and where
Dec 05, 2012 | Emerson Lc190em2 19" Class Lcd Hdtv
Admiral TV model GRD15272 video/dvd
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
May 12, 2010 | Emerson Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Hook up
You can by an AV splitter box from dick smith or even k-mart audio section that allows you to plug all your units into it, then leads go to your TV. There is a switch on the box which you flick over depending whether you want to watch a DVD or play your game unit.
The other option is to have a llok at the back of your DVD player. Some have input AV's (the red, white and yellow holes !) where you could plug your game console into. Then you just leave your dvd plugged into your tv as normal. To play your game console you turn on TV and DVD player. Have TV on "AV" channel as well as your DVD player on "AV" channel (may also be your input or component channel.
Hope this helps :)
Feb 24, 2008 | Televison & Video
RCA 32V420T 32" TV Logo
301 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
