Question about Metrologic Instruments MS5145 Handheld
Configuring eclipse 5145
Is it possible to configure scanner so it reads only first 10 digits of a EAN13 code?
On shoes and clothes the 11-th and 12-th digit often represents size, and then you can have 8 barcodes for the same article that are different only in last 2 digits (then also the check digit changes). I would like to have only first 10 digits as a product code and then the scanner have to recognize all the same products, regardles the size.
Please, can you find any solution?
Thanks!
Turning off check digit sending and adding 4 suffixes: 2 cursors left and 2 deletes, solved the problem.
Posted on Apr 21, 2008
Lock the laser on a MC9590
Hi!
You could install "DataWedge", there you can configure the functionality of the laser.
By "lock" I hope you mean "Always on" in which case you can configure that:
1. Install DataWedge on the device (If not done so already)
2. Open DataWedge on the device (Control Panel)
3. Select "Advanced Config"
4. Profiles
5. Profile 0
6. Input
7. Scanner
8. Select your scan engine, in my case "Blok buster"
9. Reader Params
10. Aim Type
11. Select "Continuous Read".
12. Exit
Let me know if you have any troubles!
Cheers.
Callum
Sep 24, 2014 | Motorola MC9500-K Handheld Mobile Computer
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
My eclipse MS5145 is locked after the first scan , what can i do ?
connect the 2nd end of the scanner cable to a ps2 keyboard and reboot
May 11, 2012 | Metrologic Instruments Eclipse MS 5145...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic Instruments MS5145 Handheld Logo
606 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
