Question about Amana SXD524VW Side by Side Refrigerator
Looking for wiring diagram for amana bottom freezer model # BG20T2L MFG# p1316303wL serial # 9807110676 THE ICE MAKER QUIT MAKING ICE
  • 1,531 Answers
First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Posted on Jul 10, 2010
Amana model aqbb1921dew
You will have to look in the freezer section and see if there are holes in the left side wall to mount the icemaker and also if you look at the left rear of freezer section to see if there is a spot for the harness to plug in. Also look on the model serial tag inside unit to see if they listthe part number to add on icemaker kit.
Jul 05, 2014 | Amana ABB1927DE Bottom Freezer...
The refrigerator is 2 yrs old and has completely quit cooling in both the refrigerator and freezer.
I looked at your wiring diagram. This ice box has automatic defrost controls. That means the temp is regulated by a computer board. Their are some diagnostics you can perform on some of these models.
Your ice box appears to be a midrange control model. Click HERE for a diagnostics video
Amana International bottom mount service manual featuring midrange electronic controls
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Amana ABB1927DE Bottom Freezer...
Amana, bottom freezer, Model No. BX21TW, MFG No. P1196515W W, Serial No. 9804248558, ice cube maker water flow exceeds the capacity of the ice maker and excess water floods the ice cube tray, forming a...
Sound like your water pump is stuck open just follow the water line at the back of the fridge and you will find the pump .Change it out and you should be fine
May 26, 2017 | Refrigerators
We are in Australia and have had an Amana XRSS287BW fridge freezer with ice maker for 5 years. The freezer is icing up near the ice maker, the condensor is not icing up. It appears to ice up and the fan...
they do not repair icemakers for the simple fact it is cheaper to just buy a new unit aka icemaker in fact the icemaker when the repairman buys it costs him between 47-90 dollars at which for him to disconnect the three bolts and reinstall the icemaker the charge usually starting around 189.00 first thing to do would be to look at the tube where the water is going into the icemaker and observe if you have a leak from the tube the next step would be to inspect the icemaker for cracks in the ice making tray if this is also ok has your repairman checked the t-stat this is a small two wire round disc like object located behind the back panel this is what regulates your temptreture and turns the heater on when your freezer gets to cold another thing to check would the drain tube that goes from the bottom tray under the condensor sometimes this also gets blocked with ice.In turn when it does get blocked the ice just builds up the t-stat is located as part number 3 on this diagram from this link http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00014?blt=06&prst=&shdMod= lastly if your fan is not spinning at the addequate speed that it is supposed to be spinning at then the amount of cold air would not be leaving your freezer to go into your fridgerator and when the heater kicked on the water that melted off the condensor coils would build up also as ice if your repairman is saying its the icemaker visually inspect the icemaker yourself here is a link also showing how to remove your icemaker http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00008?blt=06&prst=&shdMod= please message me back with your finds after you have visually inspected for yourself. i hope this opinion has helped in your appliance situation please remember to rank how this opinion has helped in your appliance situation and i await your reply
Thanks
Rick
Nov 09, 2010 | Amana Refrigerators
Ice maker quit making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 15, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Kenmore ice maker has quit making ice? Why ???
could bew a couple of reasons bad icemaker or watervalve
Mar 18, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana SXD524VW Side by Side Refrigerator Logo
335 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
