Question about Speed Queen AWS44NW Top Load Washer
It didn't fill up water.
Water goes in but after reaching about 5 inches height then it starts to go out. i cannot find near service center in my place
  • 1,531 Answers
Try to raise the drain hose so it is at the same level as the control panel but do not pull out of the wall.then re start your machine
Posted on Jul 10, 2010
Which is the good single handle sink faucet?
Eyekepper is a good sink faucet. The sink faucets come with Matching Esutcheon Cover Plate Chrome and many other amazing facilities. The faucets provide both hot and cold water and it comes with a lifetime breakage warranty and 30 day money back guarantee.
Specifications
  • Color: 6009-Chrome, Chrome
  • Finish: 6009-Chrome
  • Mounting: Deck-mounted/ Single hole
  • Number of holes: 1
  • Handle/ Lever placement: Centerset
  • Number of handles: 1
  • Main Body Material: Zinc Alloy
  • Spout reach: 3.1 inch
  • Spout height: 5 inch
  • Overall heights: 6.3 inch
  • Water Mode: Waterfall
  • Water Feature: Mix Hot and Cold
  • Water Pressure: Minimum 0.5 bar, 1.0 bar recommended
Pros & Cons
Pros
  • Beautiful design
  • Inexpensive
  • Convenient
  • Easy to install and use
  • Fine quality
Cons
  • Noisy activities
Apr 02, 2018 | Plumbing
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
My washer last nite kept filling up w water. & never would stop (until i stopped it myself)- its like the Sensot-or full indicatrer? stopped working- & needless to say it fllooded my laundry...
there is a water height sensor -- this sensor works via a small tube that is connected to the outside drum and runs down to the pressure sensor,, when water reaches a certain height the pressure sensor stops the fill cycle.
c...
Dec 31, 2010 | Maytag Washing Machines
My washing machine fills up with water, but want start washing after it fills. I can turn the knob to rince, spin, and drain, and it works. What is my problem? Is the timer ok?
Yes, i do agree, the timer will be the problem. Everything runs through the door limit to start then through the pressure switch then to the timer. The fact that you cag get the motor to spin when forwarding the timer means the pressure switch must be ok.(im taking it that the water switches off when required water level is reached. Also, if water does not switch off, make sure the drain pipe is the same height as 3/4 the tub height
Aug 20, 2010 | Frigidaire GLWS1233A Top Load Washer
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Oct 25, 2009 | Washing Machines
When start washing, filling water comes out from
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an F20 error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
Oct 11, 2009 | Zanussi ZWF1430W Front Load Washer
I have a American Standard Cadet three, it flushes properly but the bowl does not fill up with much water unless I hold down the handle....is this normal?
in the tank check that the small white hose is not kinked or has fallen away from the center tube where the flush flapper is located the white hose goes into the center and fills the bowl
Oct 01, 2009 | American Standard Compact Cadet 3 Right...
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Washer is filling up to wash but water goes out of tub before
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Speed Queen AWS44NW Top Load Washer Logo
56 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
