Question about Nokia N72 Cellular Phone
Nokia N 72 and PC connection not possible
When I try to connect my phone to my PC, I get the statement as Connection type not available, Failed to detect connection type, Code:MMList empty.
  • Anonymous Apr 22, 2008
    I have tried the answer you gave me (to insert the CD and load the drivers). Should the drivers be loaded separately or will they be loaded by default once I re-install Nokia PC Suite. I have changed my motherboard, will this have an effect on the Suite being installed. Thanks
  • Anonymous Nov 17, 2008
    se vede ecranul alb
    Scholar:
  • 47 Answers
Please insert the cd which came along with the phone and insall the driver for the phone.
also please check if the software is compatible with the operating system, if not please goto www.nokia.com and download the revlevent driver from the support page of N72.
Hope this helps..
Have a nice Day !!
Posted on Apr 19, 2008
"Failed to read the PC-FAX Phone Book"
Try this
Browse to Control Panel > Administrative tools > Computer management > Services and Applications > Services
Locate the following services:
1. Telephony
2. Network Connections
3. Remote Access Connection Manager
4. Remote Access Auto Connection Manager
Right click and select Properties. On the General tab, next to Start Up type, select Automatic followed by OK.
May 09, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Internet connectivity with pc via blue tooth on e72
go to connection settings on ur mobile go to bluetooth try to change if ur phone hs provisions for 'use phone as moderm' bt u can easily use internet if u hav a nokia pc suit and a usb cable.! Pliz let me know if dis ws helpful..
Jul 12, 2012 | Cell Phones
I REQUIRE LATEST SOFTWARE UPGRADE NOKIA 5800
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite.
OTA via GPRS:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA Wifi:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA PC SUITE:
Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this):
www.ovi.com/softwareupdate
thanks for choosing fixya.com
Dec 17, 2011 | Nokia 5800 XpressMusic Smartphone
When browsing internet appears connection not available / unable to perform operation
Thanks for your question. Listen bro the internet connection there are many types. Such as prepaid, broadband and now the modern connection is wi fi connection which is also known 3g. if you use the prepaid or postpaid connection then first you need to contract with your mobile operator. they can configure your internet setting in your mobile set. but it is not possible to use wi fi connection from your current hand set because the phone not support it, thans
Oct 13, 2011 | Nokia 5530 XpressMusic Smartphone
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
Can not detect connection settings
Actually you can run internet on your phone in this specific handset but for connecting it to PC you need to download the Pc suite of your mobile. this will be available free on the site of NOKIA.
Sep 22, 2009 | Nokia 3110 Cellular Phone
N 72
HI,
firstly install nokia pc suite 7 or above version, connect ur phone via bluetooth or data cable then click on connect to internet option.
u ll see "one touch access" window.enter in setting select ur operator then click on connect.definetly ur mobile ll be connect thrugh internet.
Thanks.
Jun 18, 2009 | Nokia N72 Cellular Phone
Unable to pair with PC via Bluetooth
beter to uninstall the pc suite and reinstall it.
May 10, 2009 | Nokia N72 Cellular Phone
Unable to cnnect internet on vista home basic
check the NOKIA site for compatibility issues for VISTA. VISTA has compatibility issues with many softwares (which may include the improper driver for your N 72)
May 24, 2008 | Computers & Internet
Nokia N72 Cellular Phone Logo
143 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
