Hello my cursor jumps around for no reason. How do I fix it
    Novelist:
  • 107 Answers
Hello Sir,
Plz follow this step,
This is quite common and easy to fix!
Click the Start> select Control Panel> click Hardware> click Mouse.
Click the Pointer Options tab, and then do the following:
Uncheck the Hide Pointer While Typing.
Click OK to save.
Hope this helps you. Let us know either way. Make it a great day!
Posted on Jul 10, 2010
Cursor keeps jumping
I suggest that you scan your computer with RadarSync so that you can find the latest touchpad driver update for your computer. It's a driver related issue.
David
Jul 16, 2013 | Sony VIAO Laptops (Laptop NOT Included)...
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Cursor Jumps, erases, making me crazy Dell Bostro 1000
what type of mouse is it? If it's a wireless optical mouse replace the batteries or throw it away, i prefer the latter
Sep 12, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Acer 5720 - cursor/keyboard: applying pressure causes jumping
Solution one: Don't apply pressure to left side of laptop :)
Solution two: Bits of hardware (like your touchpad) plug into the mainboard with thin ribbon connectors. Sounds like this has become loose, or something is shorting against something else. Solution is to take it to bits and reseat the connectors on the mainboard. Not easy to do and I really don't recommend you do it unless you know what you are doing; laptops are so fiddly and difficult to get apart.
If it's in warranty then get Acer to sort it. If not you may want to pay to get it fixed (or go with solution one!).
Aug 29, 2009 | Acer 91.63X07.001 Keyboard
ASUS eee1000HD cursor jumps
Change the sensitivity to the touch pad in the control panel.
If you reduce the sensitivity, it should fix the problem. If not, then the top part of the laptop case needs to be opened and then below the keyboard you need to replace the touch pad.
Aug 09, 2009 | ASUS Eee PC 701 Notebook
Microsoft Mouse cursor jumping around
maybe u can use mousepad, with fabric material
May 28, 2009 | Microsoft Windows XP Home Edition
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
111 people viewed this question
Alun Cox
David Payne
David Payne
