Question about Ovens
Electric oven will not bake because "loc" displays on contorl. The self-clean cycle finished 3 weeks ago. The door opens freeely and the oven is at room temperature.
  • 1,531 Answers
Try and press the clear off key for three to five seconds this should clear the display
Posted on Jul 10, 2010
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
