Question about Samsung RB215LASH
Model RB217ABPN is not making cold
We had a RB217 delivered at 10 p.m. wiithout a manual by Lowe's.  The said the unit would get cold in an hour.  It's an hour an a half later and its not putting out cold and the digital readouts on the front say "OF"
Can you help. M
  • 1,531 Answers
This means that it is off. unplug the unit for a minute then plug it back in.hold the nutton for abbout three seconds and it should turn on.you can get a manuel from the samsung web site and download one
Posted on Jul 10, 2010
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
I bought a used Maytag refrigerator, model 2254HEW. For the first month or so,it cooled perfectly, now it is taking a couple days to cool soft drinks and then not real cold. The unit is in the garage and...
HI TOM.WELL IF IT WORKED FINE FIRST THEN I SUGEST U DEFROST ALL FOR 24/48 HOURS OR REMOVE FREEZER REAR PANEL AND DEFROST ALL MANUALLY.IF U TAKE PANEL OFF THEN U MIGHT AS WELL CHECK HEATER,T/STAT.AH BEFORE THAT TRY TURNING DEFROST TIMER MANUALY.UNTIL IT CLICKSTOPS.WAIT 1/2 HOUR.SHOULD RESTART AUTOMATICALY.IF NOT THEN THATS YOUR PROBLEM.(LEVE ON OFF POINT FOR AN HOUR OR SO TO DEFROST ALL THE ICE THEN CLICK ON MANUALY AND REPLACE.GOOD LUCK.ALI
Jul 05, 2012 | Maytag Refrigerators
No water to icemaker!
i see no make and model # for your unit for i would check the internet for service manual, if the unit works when you power the solenoid manually than there is a censor or driver output transistor to the solenoid is defective and you will require a manual to service this problem, this problem location is on the control board or censor input to the board
Apr 05, 2012 | Refrigerators
My freezer works fine but the fridge does not seem to be working its a hotpoint FF187L
There is a small fan, generally accessed in the freezer. It will be behind a vented panel. Its job is to blow cold air, as needed, to the refrigerator. Usually the problem is the little motor that drives this fan.
If you have a multimeter, you can access the fan and see if it is receiving 115 volts. If it is, and the fan is not spinning, then you need the little motor. If it is not receiving voltage, then you need the thermostat (which is on the fridge side).
Either part is very easy to replace. The panels are generally attached with a couple Phillips screws, and some just have panels that snap on/off. The parts can be found on eBay or many, many online sellers of appliance parts. Also, you probably have local appliance service businesses that sell parts. You will just need the make a model number.
If you don't own a multimeter - I will be so bold as to say you should. Very handy tool. And these days you can get a cheap one (for about $10 or so at Wall-Mart, Lowe's, Home Depot etc). For household needs, you will be checking for AC Voltage. For auto needs, you will check for DC Voltage.
If this has been helpful, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Hotpoint Refrigerators
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
Freezer not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Viking Professional VCBB363 Bottom Freezer...
1994 Ford Tempo alternator light flickered when started
I would not worry about a flicker! If it was staying on, it would be time to do something.
Dec 22, 2008 | 1994 Ford Tempo
Ge profile refridgerator
unplug unit for 3 to 24 hours and then plug back in
it should work then
some of the oil inside the compressor must have travelled
up the pipes, if you leave unit upright and unpluged for at least
3 hours it should work
if this does not work you'll have to get repair man
May 23, 2008 | Refrigerators
Samsung RB215LASH Logo
464 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
