Stopped mid cycle still has water in it cant drain water or get door open or get it to start again ?
  • 1,531 Answers
You can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.once the water is gone then you should be able to open the door.then you need to check the drain hose and the drain pump for any obstructions or some thing stopping the drain pump
Posted on Jul 10, 2010
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
How do I open the door to my front loading maytag neptune? It was in mid cycle, made a horrible sound and stopped running. Has all my clothes in it and I can't open the door.
Please check this link for tips to open the door that is jammed.
Make sure to drain the water by opening the drain valve manually.
Click on : Door lock
Feb 07, 2013 | Washing Machines
MY WASHER WILL NOT OPEN THE LOCK SYMPOL IS ON
Try a spin/drain cycle once or twice, then try again to open the door. Clean the filter and pump drain
May 01, 2012 | Washing Machines
We have a Samsung front loader. Model # WF328AAIWIXAA. We started the machine to do a load, and later we were going to transfer the clothes to the dryer. It appears to not be getting power. We cant open...
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
Oct 25, 2017 | Samsung WF337AAL Front Load Washer
I stopped my maytag A5000 mid cycle and it would not turn back on i did not open the door so it cant be that switch
Have the machine taken off power for sometime and then switch it on. If the cycle does not reset or shut down to open the door, then manually release the water and open . Now after draining check again with the power on and if the machine does not start up then there are issues with the program controller unit.
check for tips on washing machine :
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 04, 2011 | Maytag Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
