Question about Northern Tool Garden
THE SPRINKLER GOES ONLY CLOCK WISE WILL NOT TURN BACK
  • 760 Answers
An exact model number would help. I'm assuming you'r refering to a lawn sprinkler that you can set say to turn 180 degrees, and then reverse back to the beginning and start over. Most sprinklers have two adjustable tabs that determine where it stops. You move these around the dial to set the stop and return positions. Then the top part of the sprinkler that moves, has a tab that can be flipped down for fwd-rev operation, or left raised for 360 degree coverage.THE SPRINKLER GOES ONLY CLOCK WISE WILL NOT TURN - 0282cdd.jpg
Posted on Jul 10, 2010
Which way do i turn the nut to loosen it for a riding lawn mower blade
Hi Ron,first disconnect the spark plug wire,for safety reasons,then get your wrench and turn the nut counter clock wise,which is left.Also remember how the blade goes back on.
Aug 31, 2017 | Garden
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
WHY IS MY RAIN TRAIN MOVING BACKWARDS
Hi there ... have you posted this question before? Not important ... I answered this question yesterday ...
ASSURE that the water arms are pointing in the proper direction. Normally, the arms should turn in a clock-wise direction to make the "tractor" go forward. If yours are going the other way, the tractor will travel backward. If yours ARE moving in a clock-wise direction and your tractor is going backward, reverse so the arms travel in a counter clock-wise direction. If it STILL goes backward, no matter which direction you are spinning, return the device to the store where you got it and ask for assistance.
I have this very device (though not this model number), though mine is LOTS older than yours is. I can make it go backward but it doesn't necessarily want to straddle the hose in reverse. All I do is reverse the direction the arms spin and vo-la ... it goes backward. BTW, I always store my tractor with the transmission in neutral to avoid damage by rough handling of others.
Jun 05, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Where are the days of the week? instructions tell you to turn the black wheel counter clock wise until day you're in hits the 14 arrow, but I don't see where the letters for the days are? My model...
Days of the week appear on day-skipper-wheel, which is the small black wheel.
To clarify your question, take a close up photo of the skipper wheel and add a comment and include that photo:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 10, 2011 | Intermatic R8816P101C -...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
I'm using it for the first time this year and it's going backward.
This is simple ... and you will smile when I tell you what you did ... you are spraying in a counter clock wise direction and you should be spraying in a clock wise direction. Rotate the arms about 45 degrees so it spins the other direction ...
Was that a smile I saw???
Thanks for your interest in FixYa.com
Aug 12, 2010 | Nelson Sprinkler: Traveling Tractor
Sprinkler timer not keeping current time of day
Open following link for Intermatic sprinkler-timer parts list
If yellow dial is not keeping correct time, then clock motor has gone bad.
Replace clock motor.
Feb 28, 2010 | Intermatic R8806P101C -...
Whirlpool dryer !
its always recomended that you turn clockwise on a timer that only goes that way but if it moves c/wise or a/clockwise with no effort then it was desighned to do this hope this helps
Jun 15, 2008 | Whirlpool LEQ9858P Electric Dryer
Garden Logo
371 people viewed this question
Top Northern Tool Garden Experts
Vernon Taylor
jeff chenault
jeff chenault
Are you a Northern Tool Garden Expert? Answer questions, earn points and help others
