Question about Dynex DX-L42-10A 42 in. LCD TV
I lost my dynex remote. We have direct tv and we always use the direct tv remote to turn up the volume. Today when we used the remote to turn up the volume; it wouldn't stop, it just kept going up. What can I do without a dynex remote to stop the ghost in my tv?
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
I went to the DYNEX website and found universal remote codes. http://www.dynexproducts.com/universalcontrolcodes.aspx
This fixed my problem between the direct TV remote and my 42 inch DYNEX plasma. There are codes for different models as well.
Posted on Jul 29, 2008
Try using the codes listed for Orion products. Worked for me.
Posted on Feb 17, 2009
SOURCE: cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
Posted on May 24, 2009
  • 19 Answers
SOURCE: trying to program the tv with the direct tv remote
The code best suited to work is 10463.
Posted on Jul 19, 2009
SOURCE: Dynex remote sticks on channels and does not always lower volume
I think you'll find that the tv is at fault. I, unfortunately bought one of these **** things as well. If you try to turn the channel, or volume, at the tv itself, you'll find that it won't work either. Seems to happen when switching between HD and regular programming a lot, but can happen at any time. You get what you ( and I ) paid for....
Posted on Oct 01, 2009
Testimonial: "I believe this person is right. I thought it was the remote control but it is the Dynex tv itself"
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
I have a Dynex 32" TV. I have lost the remote. I am using the controls on the TV, Menu, +-Volume, <> input and on/off. I am stuck in the menu and can't get out. Can you help me? Thanks
unplug your TV for 30 seconds and then plug it back in. Or just follow the directions on screen on how to use the volume control buttons and that should help.
Jan 29, 2015 | Dynex DX-L32-10A 32" LCD HDTV
I HAVE a ge UNIVERSAL REMOTE LOST CODES NEED FOR A HITACHI TV REMOTE CONTROLS TV VCR CAB. BATTERY COVER HAS RC43083826
go to www.ge.com and they should have a accessory page for remotes, and they should of a manual for your remote.
Nov 20, 2009 | Directed 434MHZ Remote Control
Trying to program the tv with the direct tv remote
Not out of luck, Dynex.com says to use codes from other model of televisions. The way I did it (I have a DirecTV remote as well) is just did a code search till I found which one turned it off. The only thing it won't do is change which input you use, but the menu, volume and channel controls all work fine.
Mar 27, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Universal remote control code
I have a Dynex t.v, but my remot control doesn't work .
Jan 26, 2009 | Directed 434MHZ Remote Control
Jun 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex tv code
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
Feb 27, 2008 | Televison & Video
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Dynex DX-L42-10A 42 in. LCD TV Logo
95 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
