Question about Roxio Easy DVD Copy for PC
Downloaded DVD Copy 4 and tried to copy a DVD. Unsuccessful. Error message says "Internet connection failed.File not found." ALso, now another box appears which indicates "Alert! Software detected that may be harmful to your computer." We need to remove Roxio from this computer, but are not able to do it. Can you tell us how?
    Genius:
  • 1,189 Answers
Hi, there seem to have been a change in your [Operating System]; so lets start with the "Highest Priority. " First, click on the "Start Button," in the Start Menu [right pane], click on the "Control Panel," next, scroll to find the ["Uninstall a Program"] applet, select and open. Now in the "Uninstall a Program" window, scroll to find the {Roxio}, click to "highlight" to Uninstall / Remove the program. Next, once the Software has been removed successfully; "Restart the Computer"
These Instructions will help you with the Internet Connection. Click on the Start Button, select in the [right pane] to open the “Control Panel,” you want to open the “Internet Options” window.
To setup the Internet Connection: Click on the “Connections” [block], click the “Setup” button, and follow all the instruction carefully. "Restart the Computer again!" Hi, again, after all the changes and fixes are done, finished, complete. Now you can click on to this "Website" to download a copy of the "DVD Copy Software." You shouldn't have any problems with the "download." If by chance you do; I'll be looking, lets hope that is not the case. Thanks for using Fix' Ya, and giving a "helpful rating, is appreciated." Click here: http://www.burn4free.com/download-dvd-copy-software.htm
Posted on Jul 10, 2010
I am Getting error 30 while installing Sage 50
Note: Not my information. Simply found with a 10 second Google search:
Issue Resolution:
Method 1:
  1. Close all installation windows of Sage 50 including the error message.
  2. Open an explorer window and browse to the DVD drive.
  3. Open the Setup folder.
  4. Right-click the Setup.exe file.
  5. Click Run as Administrator.
Method 2:
  1. Create a folder named TEST in C:
  2. Open the Computer icon
  3. Right-click the DVD drive, click Open in new window.
  4. Select all the files and right-click Copy.
  5. Go to C:TEST
  6. Right-click and click Paste.
  7. If the copy fails or there is nothing in C:TEST then proceed to Method 3.
  8. Install from C:TESTSETUPSetup.exe
Method 3:
  1. Open the Control Panel in Windows.
  2. Open User Accounts.
  3. Click Change User Account Control Settings.
  4. Change the slider all the way to the bottom.
  5. Click OK.
  6. Reboot the PC.
  7. Try installing from the DVD drive again.
  8. Open the Control Panel in Windows.
  9. Open User Accounts.
  10. Click Change User Account Control Settings.
  11. Change the slider back to where it was (usually 2nd from the top).
  12. Click OK.
Method 4:
  1. Call Sage 50 Customer Service at 1-888-222-8985 FREE to request a replacement CD as it is a defective CD.
Error
Apr 05, 2018 | Sage Computers & Internet
Micromax Modem showing "No device"
try uninstalling the micrmax software from your computer and restarts the system. Now run the micromaxinstallaion.exe file in compatible mode
May 08, 2017 | Computers & Internet
I have my pics in memory card & its nt copying to my computer . its error coming in it parameter incorrect then hw i can copy my images & i dont want loose those images???????
C:\Users\Bob\Downloads> copy Update.iso F:\
will take you here
Why is the second file copy failing?
The hint is the file extension: *.iso, which suggests that this is a CD or DVD image, and DVD images have the feature that they tend to be really big.
Like more than 4GB big.
USB thumb drives tend to be formatted with the FAT32 file system rather than with NTFS. And FAT32 has a maximum file size of 4GB minus one byte.
The user confirmed that the Update.iso file was larger than 4GB and that the USB thumb drive was formatted as FAT32.
Mind you, the error message doesn't help at all in identifying that this is what's going on. I don't know where it's coming from, but my guess is that somewhere inside the copy command, it tries to create the destination file and set its file size. Since the file size is out of range for FAT32, the call fails with the error ERROR_INVALID_PARAMETER, and that's what ends up bubbling out to the user.
But at least now you know what the confusing error message is trying to tell you.
hope this helps
Jul 03, 2012 | SanDisk 4GB microSD High Capacity Memory...
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Writer problem
try licking it and if that fails try throwing it
Jun 23, 2009 | Samsung SH-S182D DVD RW Dual Layer Burner
Windows xp installing failed
I assume you are trying to install XP from a self-burned CD.
Did you slipstream SP2 or SP3 in it?
If so, try to burn a DVD instead of a CD. I had that problem once too and followed some advice I found here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 20, 2009 | Intel Desktop Board D865PERL...
Transferring music from pc to mass storage device.
You said that you checkd the properties of all the 150 tracks right.
150 tracks is 560 MB.
The error message you are getting informs that there is nothing wrong with the player or something.
This eror rfers that the source file cannot be located by the system to transfer or the source file is corrupted.
Try the other source file.
Try transferring the other newly downloaded file.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Audio Players & Recorders
Installing Office 2007 Enterprise on new Systemax PC
i have to install
512mb ram in the system the system already have 512ram
Apr 18, 2008 | Microsoft Office Professional 2007 Full...
Dvdxcopy
First try to download from google for free Registry repair and repair registry...
If it won't help just install in another location ( DON'T INSTALL IN C-PRPGRAM FILES)
Dec 20, 2007 | 321studios 321 Studios DVD X Copy (Backup,...
Roxio Easy DVD Copy for PC Logo
42 people viewed this question
Top Roxio Computers & Internet Experts
Marvin
Marvin
Alun Cox
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
