Philips 46PP93 0217 How do I fix a blurred picture on my philips Big screen tv?
  • 2 more comments
  • kennp Apr 19, 2008
    The TV is a Philips 46in HD rear projection (Date Code July 2002) The problem: When I turn the TV on it shows a blurred picture, almost as though you are looking at it wearing 3-D glasses or have double vision.
    How do I fix a blurred picture on my philips Big screen tv? The Philips TV is a 46in HD rear projection (Date Code July 2002). The problem: When I turn the TV on it shows a blurred picture, almost as though you are looking at it wearing 3-D glasses or have double vision.
    I have adjusted the settings and even dusted it out. Still no luck.
    Thanks, I will give it a try and let you know how it goes.
    Genius:
  • 3,422 Answers
HI,
The fact that your unit first got blurry means trouble in the High Voltage section. Probably has a shorted Horizontal Output Transistor and a possible shorted flyback. If you are not experienced with TV repair you will have to enlist a reputable repair shop.
You can try out a hard reset and see if it helps.Just unplug all the cords for 4 hours and then plug it back
Goodluck,
Please don't forget to rate the solution
Posted on Apr 19, 2008
  • 3,037 Answers
You should try cleaning the projection lens on the tv first.
Things You’ll Need:
  • Screwdriver
  • Projection TV
  • Camera lens cleaning cloth
Step1 Unplug the TV from the power supply. Never undertake any type of repairs on electric equipment without first disconnecting from power. Take care in handling any electric parts, as some may contain a residual charge that can shock you.
Step2 Remove screws from the back cover and connection area of the TV. Be sure to put them in a safe place, or on a piece of paper with notations for where each one fits in the television.
Step3 Gently remove the back cover. Locate the mirror and three projection “guns,” as these are what you want to clean eventually.
Step4 Use a camera lens cleaning cloth (or other very soft and gentle cloth) to clean the mirror and lens. Gently remove any other dust before closing the TV.
Step5 Replace the back cover and screws. Plug back in the power supply.
Step6 Turn on the television. Check to see that everything works correctly and that your picture is now clearer.
Let me know if that helps or whether you feel comfortable doing it or if you need anything else pertaining to this tv.
Remember to be careful when working on electronics
Thank you for using Fixya and Have a Good Day!
  • Benjamin Patri
    Benjamin Patri Apr 19, 2008
    sounds good
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Brigadier General:
  • 3,614 Answers
Have you done any of initial check on the unit..? like adjusting the or changing the settings on the menu..
Thanks
  • micromaster
    micromaster Apr 19, 2008
    Take out the comb filter and
    replace the surface mount electrolytic capacitors (I think there were
    around 4 of them) on the comb filter and put it back in the
    motherboard. MCM sells a kit If I'm not mistaken with capacitors
    that fix this problem as well as the picture in picture problem which
    these same sets have.
  • 13,433 Answers
I beleave the converence ICs would need to be replaced there is a very detailed tutorial on that, il get it for you.
    Genius:
  • 1,142 Answers
Can u give some more details about the problem
How to format the picture to fit the screen with a universal remote (the one we have is not a philips remote)
Hi there. It is a common problem with replacement remotes. Some features like the one you describe will not be available in this one.
A Philips replacement remote is the solution. Best of luck.
Apr 19, 2014 | JVC AV-32020 32" TV
Our tv has a blur with a picture that is off centered. The shop said it needs convergence, but would I go about fixing it?
Convergence ICs will be big black ICs will have PN# on them ,example STK392-110
Mats has them 1-800-628-1118
Encompass Parts Distribution might have whole board 1-800-638-3328
Oct 21, 2010 | Philips 43P8341 43" Rear Projection...
1/2 picture doubled while other half is normal. Philips E10839
Its a convergence problem which is common. Goto www.TvRepairKits.com and get a kit for your model
Jun 03, 2010 | Philips Televison & Video
Blurred picture from my Philips 230NC webcam. This has
If it's only 3 weeks old, take it back to where you bought it, and get it fixed or replaced.
Apr 05, 2010 | Philips SPC230NC Webcam
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sound but no picture
Take it to a repair shop and let them fix the problem.. we charge around 300 to 400 fixing something like that...
Aug 31, 2008 | Philips 55PP9363 55" Rear Projection...
Philips LCD picture too big
depending on your cable syayem there might be an easy solition right on your remote or as a setting in your box - they have zoom settings also that seem to superseed all settings your TV has
Apr 22, 2008 | Philips 42PFL5332D 42 in. LCD Television
Picture is to big for the TV
when i turn on my tv just only half screen appear on my TV screen, do u have any i dea to fix this problem.
Apr 05, 2008 | Philips 20DV6942 20 in. TV/DVD Combo
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
