Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Standy-by light blinking 7 times
My Sony is doing the same thing that you described. Was the TV expensive to repair?
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). This could have happened during the moving process. The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson Apr 26, 2008
    P.S. Before you assign a rating, please
    make sure that the issue is resolved or you are satisfied. If not, please post
    back as to what you did, and/or any other questions you may have, and I will
    try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
    ‘Thanks for trying’ rating if your issue is not resolved after the first
    response itself, as sometimes a bit of to and fro dialogue may be necessary
    before we can find a fix or an answer to
    your query.
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please close the ticket with a FixYa! rating.
    I would be very grateful for your show of appreciation.
    Thank you for using FIXYA!
    Cheers,
    IrishDruid
Blinking standy light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Sony Bravia KDL-32BX320
32 inch emerson lcd tv standy light is on power light flashes
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 11, 2013 | Televison & Video
Sony kv24fv12 in standy mode
In standby mode, the standby light must blink to certain times. If it do so, count the number of blinks at one time. These blinks are fault indications. After counting it, visit this site for more details. [Electro-help].
Type in the site name, either to Google or Yahoo search box and click search. You can see the site in same name as above. It is an electronic equipments repair help site.
Sometimes, you might make it right.
May 10, 2012 | Sony KV-24FV12 24" TV
Sony Bravia KDL52W300052" flat screen -- blinking standy light 13 times...... This better not be expensive! I think it's a recall item.
Hi there! I think this will be a job for a repairer. The Amount of times the LED flashes will normally determine what the actual cause may be. There is no indication in the service manual for 13 flashes unless you have more than 1 fault. Check for pauses between flashes. It may flash 6 times and then 7 times to get to 13 which will mean 2 Errors. Check these out first and then decide. It will still require a skilled repairer to fix this fault. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Trinitron Won't Turn Back On. Standy light blinks continuously.
could be any number of things ranging from the power supply regulator to the vertical chip audio chip or even the flyback transformer. Definately not an easy fix and would definately be over $200. The flyback alone original from Sony would probably amount to that .
Oct 08, 2008 | Televison & Video
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega tv is not staying on it turns off when the standy by light turns on
do you get a blinking light if how many times does it blink the pause then blink?
Feb 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
