Question about Sony SLV-940HF VCR
Vcr wont play properly tracking seems to be off i have opened up the vcr player and given everything a good inspection but cant see any obvious issue with the ''mechanics'' of the device. The tape being loaded played and forward fast and rewind all work but when any tape is played the tracking is ''Off: and a distorted flicking acroos the width of the TV screen is seen about 3/4 of the way down the picture being projected on the TV.. How / what causes this and can it be easily fixed. Sound seems to be fine..
  • Sony Master
  • 17,130 Answers
It is possibe that the guide of the tape transport is gone a little off. This can happen if the guide has not loaded properly. check inside for obstructions to the link. if not try to screw down the half split screw a little down on either side to release the tracking/ noise onthe screen. Also clean the tracking head which is also the audio head. clean your roller if this is holding down the tape. Please do this with caution and care. clean your head and also the lower section of the head drum for dirt. you will see accumulation on/under the lower drum , Hope this helps. Good day
Posted on Jul 15, 2010
The VCR is completely off track.. Does anybody has any solutions?
If by "off track" you mean it cannot track an image on the tape, it may just need cleaning. The heads, head drums, guides, and rollers in the playback mechanism require cleaning on a regular basis and, if they are not cleaned regularly, oxide particles and dirt accumulate to the point that the VCR is no longer able to play tapes.
Although automatic head cleaners are available, they're more for maintenance, and if it isn't playing tapes anymore it's beyond that. I would recommend taking the VCR to a repair shop for cleaning... shouldn't cost very much, and it should solve your problem. (Let's hope that the heads aren't worn down... bit more of an issue.... but try the cleaning first.)
Once you have the unit running again, buy an automatic cleaning tape and use it every few plays.
May 21, 2015 | Panasonic DMR-E75V DVD Player/VCR
I am having problems with the tracking at the top of the screen. This was given to me so I have no remote. Is there anything I can do without the remote?
First make certain the video heads are clean. If OK then most VCR use the up down TV channel selector to adjust the VCR tracking when in play. To test put in a good tape and play it, then keep your finger on either up or down button. If it works it should stop tracking properly (pressing the other control will bring it back).
Jan 09, 2011 | Emerson EWV404 VCR
Can't figure out how to adjust VCR tracking
Open the player, use cotton wool and methylated spirit to clean the play head of your tape player and the picture will be clear. It is dirt that is making the picture shaky.
Its not all the time that tracking can solve the problem. So clean the player's play head and all will be well.
Please don't apply too much spirit and make sure you dry it with a dry wool. Also make sure the player is turned off and removed from electricity before you proceed for the cleaning.
This is the help that I can render to you.
Good luck.
Apr 23, 2010 | Quasar VHQ401 VHS VCR
Picture rolls and the tracking is off.
do the heads need cleaning? sounds like the heads are seriously out of alignment? take off the vcr cover get a philip scrdrv. put tape in. and play. theres an AC head just to the right of the drumhead. jiggle it around gently. u may have to adjust those 3 screws (precison) to put it back in proper adjustmant. also take the tapes u used in that vcr. open the top flap and inspect. are there marks? is there a line going the bottom portion of the tape. if so , it definitely is out of alignment.
Aug 14, 2009 | Philips Televison & Video
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
Zenith xbv442
I had to tear mine all apart and clean everything and re-align everything. If you arent a pro you may want to take it to a shop or buy a new one.
Jan 25, 2007 | Zenith XBV442 DVD Player/VCR
Televison & Video Logo
138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
