Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump will not push water out
I have had this pool and pump for a MONTH- I have been gentle with it - the out put from the pump will shoot hard for about a min then decrese, until it stops putting out, The motor is still running- I have trouble shot the following- insured all of the lines are clear and have purged them. made sure all of the lines are open and flowing. The filter is clean and intact- made sure there was no air in the lines, and that there is nothing in the jet that shoots into the pool. When you mess with it - it will work for about a min. was thinking about taking it apart- (motor)
    Problem Solver:
  • 10 Answers
Have you added diatamacious earth aka D.E. to the filter.
Posted on Jul 10, 2010
I have a fish pond and our new puppy has pushed some of the rocks surrounding the pond into the pond and has torn the liner. What is the best way to repair this.
drain fish pond see what kind material the liner is made of and trouble shoot get a bulge pump pump the water into something that can hold it maybe like a kiddies swimming pool or something like a bigger yard swimming pool for fish and water wlmart sells swimming pools
Feb 20, 2013 | Fish
I primed my pool but water starts shooting out of the top of the vent and it is not a constant flow it stops than gives a push of water . I have a small 12'x30
Okay finally found the question again...
not enough info:
are talking about the pump...to what vent do you refer to. ...never seen a vent on a water pump. Are you talking about the priming filler cap? It should be sealed! Check the gasket perhaps it fell off and you missed it when replacing??
May 27, 2012 | Pool & Spa
Water not pushing out hard
it may need fresh sand in the filter or back flushing? it could also be the pump motor getting claped out
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
We have a hole in the top ring of our pool how can we find it?
You might try letting water out to the point where the ring could fall or be pushed over into the remaining water. Then inflate the ring and squeeze a submerged area gently. Look for bubbles.
Jun 09, 2010 | Intex Easy Set Pool 15x36
Have a dolphin dX3- put it in the pool and it's floating; won't sink to the bottom. Pool water temp is 55 degrees.
the hose must be filled with water. Hold the hose up to where the water shoots into the pool and force all the air out of the hose line. The dolphin should sink.. Then connect the hose to the suction side
Mar 06, 2010 | Smartpool Dolphin Robo - Kleen Above...
Back - siphoning when the pump turns off.
Make sure you dont put too much sand it will come back out.Put the correct amount and bump the pump correctly.
Jul 23, 2009 | Water Pik Flow Valve Assy. Series II...
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
3 1/2 month pump burnt up today when removing water in waste mode
sand will burn out moter when you replace put a screen of fine cloth and clean 1or2 time a month
Nov 14, 2008 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
360 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
