Question about Honda Car Audio & Video
How do you remove old radio cassette from honda legend 1992
  • Honda Master
  • 4,991 Answers
Www.fitaudio.com/index.php?CategoryID=14
Posted on Jul 10, 2010
How remove the trans out of 1992 Acura vigr
1992 Acura Legend Manual Transmission problems ...
? 4:21
www.youtube.com/watch?v=iB7p0PKrDIA
Jan 1, 2012 - Uploaded by Ryan Kucan
1992 Acura Legend Manual Transmission problems ... How toremove the shift linkage pin from a Honda Acura transmission - Duration: 1:56.
Sep 12, 2015 | Acura Cars & Trucks
Is the harmonic balancer on a 1992 acura legend tapered
No, it is not. Acura, and Honda Harmonic balancers, (the crank pulley), come off fairly easily once unbolted. Sometimes you have to pry on them a little, but I've never had any difficulty removing them.
Apr 22, 2015 | 1992 Acura Legend
I NEED TO DECODE MY AUDIO SYSTEM STD.MODEL FOR A 1992 ACURA LEGEND
your book should have a security code in it that you can put in after starting your car- after numerous times of failing with a code tho- the security will lock- unplug the battery and try again. i had this happen with my 98 acura tl 2.5
Apr 14, 2013 | 1992 Acura Legend
1992 Acura legend radio code
There is a little card (biz card size or smaller) or sticker with a code on it in the Owner's Manual. Well, they actually issue it separately and you're supposed to keep it with your car documents somewhere.
If that is lost, the only legitimate way I know of is your local Honda/Acura dealer. They will get it for you based on the serial number of the radio or the VIN of the car. They will charge you labor to extract the radio from the dash to get the serial#. If you pull the radio yourself they may waive the fee, but you should have the matching car there with you so they will feel comfortable it's not hot. I wrote the code for my old radio in sharpie right on the radio - you could check to see if someone already did this before.
Aug 09, 2010 | Car Audio & Video
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Apr 04, 2010 | 1992 Acura Legend
Need radio code 1992 acura legend
need to pull your radio out and get the serial number, call the local dealer to give you a the code. they may need you to come in with ID and charge you a small fee
Mar 28, 2010 | 1992 Acura Legend
No fm radio stations tune in. 1993 Acura Legend/ w Bose radio/cassett. AM works great. verified all antenna connections already.
Not much it can be really. If it is picking up A.M. no problem then it is not a connection problem. It is a fault in the radio itself. F.M. frequency is the easiest to pick up so get the radio checked as it has to be internal.
Aug 04, 2009 | 1993 Acura Legend
I need radio wiring diagram for 2004 honda civic sedan and instructions on how to remove the radio
I just installed a radio and speakers in my 1992 Civic LX (132323 miles). Most radios are removed by disassembling some of the dashboard components. On mine I had to remove the lower center console (where the ashtray/lighter is located) to access the rear of my old radio. There is a metal support strap back there which stabilizes the radio and provides equipment grounding. This has to be removed from the radio before you can un-install the radio. Also there may be a metal mounting sleeve around the radio, if so you must use (2) thin metal strips (or thin screwdrivers)to disengage the (2) side clips from the sleeve. You should then be able to remove your old radio.
As for wiring , I had to discard the wire harness the came from the old stereo and hard wire the new unit. I used a 12v circuit tester to find my (+) positive (typically red) and (-) negative (typically black) leads. Speaker wires are in pairs. (example: blue/white white/blue or white/white-black)
Oct 29, 2008 | 1992 Honda Civic
1992 Accura Legend Back speakers
you need to remove the rear deck to get to the speaker, that means the rears seat need to be remove too to get to the rear deck
Sep 20, 2008 | 1992 Acura Legend
Car Audio & Video Logo
114 people viewed this question
Top Honda Car Audio & Video Experts
Marvin
Marvin
Chris Ward
Are you a Honda Car Audio and Video Expert? Answer questions, earn points and help others
