Question about Microwave Ovens
Charmglow Remote Cooking Thermometer - remote temp not showing (flashes but no temp) remote is on and probe is inserted - shouldn't probe give a temp even if it is room temp
CharmGlow remote thermometer Probe temp not indicating any temp.Just dashed lines??
Posted on Dec 09, 2010
I am cooking a roast beef dinner for Christmas I bought a 13lb chuck boneless and I need to know how long to cook in in a traditional oven.
5 After browning the roast at a 500°F temperature in the oven for 15 minutes, reduce the oven temperature to 325°F. To figure out the total cooking time, allow about 11-12 minutes per pound for rare and 13-15 minutes per pound for medium rare.
Really, you need a probe thermometer. Leave it to rest for 15 minutes after you take it out of the oven, loosely tented with foil. I am a chef!
how long to cook Google Search
Dec 24, 2016 | In Microwave Ovens
Instructions for reheating
same as for cooking. Get yourself a probe thermometer. Reheat on full power until the internal temperature is 165'F. Don't use the microwave with the thermometer in the microwave!
Aug 12, 2015 | Microwave Ovens
Panasonic microwave does not achieve desired temperature
They never do ! You have to check the temp at where the air comes out of the fan and you need to use a remote electronic thermometer.
the old oven type won't work sitting on a the shelf. 275 degrees at best. Take it back it's not broken ...the just don't work as advertized
Apr 07, 2014 | Panasonic NNCS596S Microwave Oven
Cooking with metal probe not fully inserted into ham Frigidaaire Gallery Series Micro....noises occurred ...popping sound....and microwave shuts off....no visual evidence on buttons or surface ...can it be...
Unfortunately when the metal probe was inserted in the ham it caused the magnetron to arc to the probe causing it to short out, but usually the thermal fuse will open and shut the system down preventing damage. It usually takes 30 to 60 minutes for the fuse to reset and allow the microwave to run, try heating water! if you are lucky the oven is unharmed. But if there no change the magnetron will need to be replaced which probably would not be cost effective, cheaper to buy new unit.
Mar 07, 2011 | Frigidaire Microwave Ovens
Digital temperture gauge where should readings range and how much varation should occur when door is opened ( cause and effect)
You cannot place a digital thermometer or even probe into a microwave oven cavity that is switched on and cooking, without danger and damage!
Feb 13, 2011 | Microwave Ovens
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
I have a frididare oven ple8389echthe top works the oven is giving me an f30 error what do i do
F30 is effectively a faulty temp probe.
The temp probe must be tested before replacement.
Testing is done using a mutimeter set on Ohms to read impedance on the temp probe terminals If reading resistance at room temperature returns less than 500 ohms, then replace the Sensor Probe.
If reading is more than 500 Ohms , then check or shorted Sensor Probe harness and eventually replace the wiring harness.
Model PLE8389ECH did not return anything, if model is PLES389ECH then here is the sensor probe :
Here is the probe for PLES389ECH : PS820208 for $39.
It is Part 37 on the left in the diagram below:
If my solution had been helpful, then please do not forget to accept the solution.
Thanks.
G.
Jul 05, 2009 | Microwave Ovens
1) What's the expectect temp range for 1L water, for GE load test for 1KW ovens? 2)Why didn't my brand new oven come with a repair/maintenance packet like my old one did? Tom
1) MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
2) If it's not
hidden either behind the grille or control panel, they may have left it out as a cost-savings measure.
Nov 26, 2008 | Microwave Ovens
Microwave Ovens Logo
758 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
