Question about HP Compaq Presario SR2150NX PC Desktop
Can a second monitor be attached without having to buy any other?
Can a second monitor be attached without having to buy any other adapter or attachment? I need to attach a second monitor but this PC does not seems to have an inbuilt facility to accommodate it.
  • HP Master
  • 6,826 Answers
If you buy another graphics card and it has this feature, you can do it.
Disable the old on board graphics card first.
Look for the appropriate VESA, PCI, or PCI-Express interface in your manual available online,and make sure the new graphics card works with your motherboard.
Posted on Jul 10, 2010
Any way to hook up my monitor to my Pc? It appears the laptop has a mini VGA port, but my monitor only has the regular size VGA port.
At the store they have adapters you can buy. WHen you get that just connect the mini part to the laptop and add the attachment and connect it to your monitor.
Oct 28, 2013 | HP Computers & Internet
Connect ps3 to acer model AL1702W
There are two options:
- Buy an adapter cable (HDMI to VGA) and plug into the monitor that way.
- The second, better option is to buy a new monitor because the PS3 outputs a higher resolution than your monitor does right now, causing the PS3 to scale its output down making it look worse.
Jun 19, 2012 | Video Game Consoles & Games
Will the serial number of the waterrower enable WaterRower to know whether a waterrower without any monitor can have a monitor attached without the owner having to drill any holes into the machine? I...
Good Afternoon, ABC9363:
You may buy with confidence. There is a retrofitting device available so that all units can fit the S4 monitor. You will find it here:
http://www.waterrower.biz/service/service_menus/spare_parts_price_list.htm
Part number WRP- C110S4 is the computer backplate assembly.
Happy Rowing!
Chr
May 17, 2011 | Water Rower WaterRower Classic Rowing...
When i turn the laptop on it just beeps several times and the battery and the circle with a Z looking thing light up.
Ok, the tilted-Z-in-a-circle represents the power indicator. As far as I know the power indicator is orange while the battery level is below 60% and charging, and green above 60% and charging. When the batery level is above 90% the power indicator starts blinking (green blinking) to let you know that the battery is almost fully charged.
Please try to turn on the laptop without the battery attached and secondly without the power cable attached. Does the laptop still beeps?
If yes, this could indicate a failure of the battery / charger / mainboard charging bridge.
First, if the battery starts to fail, you should be able to start the laptop by removing the battery. If this helps then you have to buy a replacement one.
Second, check the power the charger outputs (by using a voltmeter) and compare the voltmeter reading with the power adapter specifications (read the sticker on the power adapter). If there is a difference of more than 1-2 volts then it means that the power adapter is toasted. Buy a new one and everything should be ok.
Third - if the mainboard charging bridge has problems - this can only be investigated by a laptop service specialist. It can be fixed either by replacing a passive part or by replacing the motherboard.
The beeps you hear can be a code by which the laptop tries to tell what the problem is.Please describe the beeps and the timeout between them(e.g.: beeeeeep-------------bep---bep---bep -- this is the signal that the VGA adapter is no longer recognized).
Please rate this solution to keep the good answers comming!
Good luck with your tabled PC !
Dec 04, 2009 | IBM ThinkPad T43 Notebook
My im600 is new but never charged my ipod. It played OK at first but the adapter does not charge the battery. The player does not play without the battery and then only for about 5 seconds. Is it just a...
First of all, did you fully charge the battery using the A/C adapter before initial use? If your ipod does not fit with any of the attachments correctly, try just placing it on the dock without the attachment & it should connect fine just be sure it's connecting to the dock properly. I have the ipod nano 2nd generation & the attachments don't work, but it fits on the dock well without the attachments & works great!
Jan 25, 2009 | Altec Lansing Inmotion-IM600...
Can I use the EN-7500 monitor without connecting to a computer?
no problemo, if you know exactly what the monnitor need S(kind of socket, Volt and ampere), go head...
cheers
Dec 26, 2008 | MPC Computers Envision EN 7500 17" Flat...
THE MONITOR SONY SDM M81B HAVE HDCP??
A DVI to HDMI cable should work, I have the same monitor, but attached to an Xbox 360, if that doesn't work then buy a HDMI Cable and a HDMI (Female) to a DVI (Male) Adapter
Cheers
Nov 03, 2008 | Sony SDM M81B (Black) 18.1" LCD Monitor
Ground Noise Problem Possibly Attributed to Samsung Monitor
Do you have another power adapter to try? Sometimes those go bad, and are pretty cheap to test out (around $35-$50). Otherwise it is the DC-in board on your PowerBook. I replace about 2 of those per month with our clients up here on the PowerBooks (and iBooks). The DC-in board on your 15" is also part of your sound board.
Jul 29, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I am unable to find a 12volt computer power cord for a Pro View Monitor I purchased second hand. I even bought a one size fits all deal that did not work. Can you help me.
dear cate
you buying this without a power adapter
but you can buy this separate the type is
Proview SA-769 11 TO 14 Volt AC Adapter
it's price about $ 54 and mybe you can find the second hand about $ 20
oke
cropp
Mar 15, 2008 | Computers & Internet
HP Compaq Presario SR2150NX PC Desktop Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
