Question about Whirlpool GEW9250 Electric Dryer
The control lock will not turn off. - Whirlpool GEW9250 Electric Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
My 2003 GMC ENVOY won't shift out of park
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid
The automatic transmission shift lock control switch
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
  1. Turn ON the ignition.
  2. Press and hold the brake pedal.
  3. Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the automatic transmission shift lock control switch.
  3. Turn ON the ignition, with the engine OFF.
  4. Attempt to move the shift lever out of the PARK position.
Go to Step 7
Go to Step 4
  2. Leave the automatic transmission shift lock control switch disconnected.
  3. Connect a test lamp between the A/T shift lock control solenoid supply voltage circuit at the automatic transmission shift lock control solenoid and a good ground.
  4. Turn ON the ignition with the engine OFF.
Does the test lamp illuminate?
5
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and a good ground.
  3. Turn ON the ignition with the engine OFF.
Go to Step 6
Go to Step 9
6
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and the park lock solenoid ground circuit.
Go to Step 8
Go to Step 11
7
Inspect for poor connections at the harness connector of the automatic transmission shift lock control switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 13
8
Inspect for poor connections at the harness connector of the park lock/automatic transmission shift lock control solenoid assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
9
Repair the open or high resistance in the park lock solenoid ignition 1 voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
10
Repair short to battery positive voltage in the A/T shift lock control solenoid supply voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
11
Repair the open or high resistance in the park lock solenoid ground circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
12
Important: Depress the button on the side of the shift lock actuator. With the button is depressed, cycle the plastic straw within the shift lever 3 to 5 times. The straw should move smoothly and freely except near the top of the travel where additional force will be required to mechanically actuate the park lock mechanism inside of the shift lock actuator. If there is stick/slip or abnormal friction while cycling the plastic straw or if the straw is altogether stuck in the lever, the entire control assembly (shifter and shift lock actuator) needs to be replaced. Refer to Transmission Control Replacement . If there is no abnormal friction, replace the shift lock actuator. Refer to Automatic Transmission Shift Lock Control Actuator Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the automatic transmission shift lock control switch. Refer to Stop Lamp Switch Replacement in Lighting Systems.
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jul 09, 2016 | GMC Cars & Trucks
I can't start my dishwasher. What lights up is control lock. I've never had this problem before.
To turn off control lock - Press and hold control lock for 3 seconds. The control lock light should turn off.
Sep 25, 2015 | KitchenAid Dishwashers
How do I turn off the control lock on a whirlpool duet washer?
To unlock the controls select and hold END OF CYCLE SIGNAL for 3 seconds untill Control Locked status light turns off
Sep 12, 2014 | Whirlpool Washing Machines
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
My washer has the control lock on how do I unlock it?
The Control Lock is unintentionally turned on. Press and hold the End of Cycle button until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it. The control can be locked by pressing and holding the same button until the Control Lock light turns on.
Oct 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you turn off the control locked key?
To enable the Control Locked feature when dryer is
running:
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
to turn this feature off.
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
The Control Lock light is on. How do I turn it
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore elite, im locked out and cant reset, no heat dry is not working to unlock get my wife off my back
I took off the lower panel and found some paperwork that gave option notes. under control lock it says "the Control Lock light is turned on and all keys of the keyboard are disabled wheneverthe control lock feature is involked by the customer. The Control Lock feature (and light) can be turned on or off by the costomer at any time by holding down the Air Dry option (water heat/ no water heat) key for 4 plus aeconds." Now I held it down (pushed) longer until the Lock light turned off, then If it doesn't turn off I did it to the no water heat and light turned off.
Hope this helps.
Mar 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Duet washer
PRESS AND HOLD CONTROLS LOCK/UNLOCK (END OF CYCLE SIGNAL)FOR 3 SECONDS.
Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
