GE Model WBVH6240 washing machine
No water enters the machine dlicks 4-5 times makes noise like it will rotate, but doesn't move
Might be the water inlet valve. It is located just behind where your water hoses attach to the washing machine. Pretty simple and inexpensive place to start. Shut off the water supply to the washing machine, disconnect the hoses, remove the small cover and you should be looking at the valve the hoses were attached to. Ideally, you should get the part from this site since they provided the money saving info. If you can't figure out part info, next choice would be your local (not big box retailer) appliance store. Just take in the valve and tell them what model machine you have and they should be able to help. There are many useful diagrams and instructions on the web if you need more specifics.
Posted on Apr 19, 2008
Ge washing machine glwn5050mows loud spin noise
Replace the "tub damping straps" on the unit. Here are the parts to order and the is a video on that same page to show you how to access it. I think there are 4 straps on that unit.
Nov 20, 2013 | GE Washing Machines
GE WASHER MODEL WBVH6240 DRUM NOISE
No it's supported by bearings I believe you have bearing issues look your model up on partselect dot com and take a look at assembly
Aug 03, 2017 | Washing Machines
My question is; the washer,model,wbvh6240 has any filter
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Mar 15, 2011 | GE WBVH6240F Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Ginding noise during agitation
From the GE site.....
Front load washers and some compact model washers do not come with a shipping rod. According to the Installation Instructions for these machines there are 4 bolts, 4 yellow plastic spacers, and 4 metal "p" clamps that need to be saved and reinstalled before moving the washer to prevent any damage to the machine.
Jan 31, 2009 | GE Profile WPSR3120WWW
GE WBVH6240
Disconnect power to machine,
Drain all the water you can.
Remove the bottom access panel ( 3 screws on bottom plate)
open the large plastic filter in center
have a tray and towels to catch the water,
remove all clogging material,
look in with a light and turn the pump , it should turn freely.
Jan 27, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
