Question about Maytag Neptune MCE8000AY Electric Dryer
Upper dryer not heating /drying clothes.need new lint filter.
  • bnsmarks Jul 11, 2010
    WE HAVE NOT TRIED THE SOLUTION YET.UPPER DRYER IS STILL NOT HEATING/DRYING.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The most common thing that goes bad is the thermal fuse. If it is bad dryer wont heat and sometimes won’t even turn on. If that is fine and you want to buy the lint filter you can check this link for its parts. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
  • 23 more comments
  • bnsmarks Jul 10, 2010
    Need a solution can it be fixed?
  • Rylee Smith
    Rylee Smith Jul 10, 2010
    The issue will be resolved after checking the
    thermal fuse and if it is fine then you’ll need to replace the lint filter. You
    can buy it (Part # AP4043000) online from the link---
    Maytag
    Lint Filter
    Thanks
    Rylee
    I do not have a lint filter for the machine. it broke ..will a new one fix the top dryer ? the bottom dryer is working fine?
  • Rylee Smith
    Yes it will
    how do I CHECK THE THERMAL FUSE?
  • Rylee Smith
    The Thermal Fuse which is
    mounted inside the back cover panel to the exhaust duct and is mounted in white
    plastic housing.
    SO A NEW LINT FILTER WILL CAUSE THE TOP DRYER TO WORK? AM I UNDERSTANDING THIS RIGHT>????
    a THERMAL FUSE IS NOT NEEDED If I BUY A NEW LINT FILTER?
    or do I need to check the thermal fuse too? If so how do I do this? thanks
    how do I know if the thermal fuse is not usable?
  • Rylee Smith
    You are right...start with checking the Thermal fuse...you can test continuity between its two legs, if the continuity is there then it is the lint filter that should be replaced. However, no continuity means that the Thermal fuse should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    I do not understand how to check the fuse. mIGHT need to call a plumber to help. cOULD you speak to my husband to guide him to find and check the fuse?
    we are trying to find the thermal fuse now... is the lint filter you suggested the correct one for maytag dryer MCE800AYW?
    mce8000ayw is the dryer number
    how much does a thermal fuse cost?
    The machinae goes on electrically, but there is no heat, would the machine go on if the fuse is blown?
  • Rylee Smith
    You can buy the lint filter from this link and thermal fuse from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Do we need to take the back panel off to get to the fuse?
    can't accept solution because problem not resolved yet. Need cost of fuse..please?
    do we need to take the bck panel off to check he fuse?
    Are you still here? Please answer my last two questions
    thanks
  • Rylee Smith
    I am still here the cost of fuse is $21 have already sent you the links from where you can buy them which also shows the cost. I was searching for a repair manual in my database that was the reason was unable to respond. And yes, not forcing you to accept anything.
  • Rylee Smith
    Please check this link for repair manual. This is a common one for all Maytag Neptune Dryers.
    wE ARE HAVING TROUBLE USING THE MANUEL. qUESTION do we need to remove the back panel onthe lower part of the dryer to get to the thermal fuse?
    need answer to last question
    thanks
  • Rylee Smith
    YES, you'll need to take the back off. Part#21 in this picture is the Thermal fuse
    Thanks for all of your help.we are going to order the lint screen. My husband is scared to open the back of the dryer. He says the sides and back are attached and it is a big job. I hope we find someone to do this so we can check the thermal fuse.
    SUSAN
DRYER HAS NO HEAT. TUMBLER TURNS OK. LINT FILTER CLEAN.
Make sure the dryer exhaust tube is clear of lint and not kinked. Next thing I would check are the thermal fuse and thermostat. Check this out: http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
May 05, 2015 | Washing Machines
Dryer not drying
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Feb 18, 2014 | Tricity Bendix Dryers
Lint is stuck in door seal and clothes are not drying
sounds like the lint filter is clogged up, replace it with a new one if possible or give the old filter a good wash, let it dry and try again
Jun 03, 2012 | LG DLE5977 Electric Dryer
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Dryer heats up but clothes won't dry
Check that the lint filter is not blocked or that the oulet hose is not kinked
Feb 04, 2010 | Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
